my trans has a bad flair when shifting 2hd to 3rd
Discussion in 'Transmissions' started by jayss10, Jun 15, 2013.
  1. jayss10
    jayss10 This is Minerva
    INDIANA
    1971 MAVERICK,73 GRABER CLONE
    took my car to track this weekend, ran great,shifted great 1st time down ,but when i was ready to run it hard it worked great 1st to 2nd,but when i went to shift into 3rd it flaired like there was no gear there,well when i was driving it home it was doing it also leaving it in drive,but when it got into drive everything was fine,no slip pulled hard,but when shifting it slips,i had a shift kit installed ,im lost any help
  2. groberts101
    groberts101 Member
    Minneapolis, MN
    Sounds like it's valvebody related to me and I can't remember what circuit is where anymore.. at least until I get back into mine to freshen it and my memory up.. but you'll probably be best served to drop the valvebody and disassemble/clean it up.
    While you're in there.. check bores and valves for wear/scoring/sticking/burrs/etc.
    oops.. almost forgot to mention.. check the band adjustment and disassemble/check servo piston seals/bore as well.
  3. jayss10
    INDIANA
    will do im really bummed ,i want to race it in ia when we go ,it 1.62 60 ft so i know it was going to really run
  4. groberts101
    groberts101 Member
    Minneapolis, MN
    I wouldn't sweat it too much since it did run well the first time out. If you did in fact fudge the valvebody mods with incorrect orriface sizing(which will cause that type of flare).. it wouldn't have run well the first time down the track like it did.
    Could be something simple like debri or a rolled/ripped servo seal.. and I myself would be hot on it if some racing was involved. :D
    And if it's fresher.. u may get by without replacing any gaskets at all if you're careful during disassembly. (y)
  5. 71gold
  6. MaverickDan
    Midlothian, VA.
    73 Maverick 4dr
    Mine did this too, turned out to be the vacuum modulator.
  7. jayss10
    INDIANA
    Up date went out to move the maverick,transmission shifts perfect,maybe I need a cooler,any ideas guys.
  8. maverickmadness
    maverickmadness Member
    ala
    1973 maverick grabber, 1972 maverick grabber,1974 maverick grabber,
    servo
    I bought a c code servo from sonnex and it solved the flareup for me.
  9. jayss10
    INDIANA
    I think I'm going that way also.....
