mystery C4
Discussion in 'Transmissions' started by newtoford, Sep 1, 2008.
  1. newtoford
    newtoford Member
    New Castle Delaware
    guy that sold me the 351 also GAVE me this. said it came out of a running car years ago. i think its a C4?
    look like anything special aside from a good core to hang on to?
  2. don graham
    I'm no expert but it looks like a 74 c-4, big bellhousing to me. And it's got an 82 mod to it. I'm sure Paul will be on in a while to tell us what it really is.:)
  3. newtoford
    newtoford Member
    New Castle Delaware
    ya, the D4 and E2 part numbers had me a little confused too
  4. PaulS
    Can't see if the pan is deep or not - No way to tell the date without the numbers of the two circles above the shift lever. If you can post a picture of the front without the converter in it I can tell if it a big bell housing or not. If it has a pane that is about 1 2/4" - 2" deep then it is most likely a C5 - convert to C4 with a 70 or later valve body and a new bell housing and converter. ( or use the same bellhousing and a C5 converter). Either way it has all the good stuff in it so it is a VERY GOOD core at least.
  5. newtoford
    newtoford Member
    New Castle Delaware
    i'll definatly get some more pics up and i know for a fact that the bell housing is biger then the bell on the c4 that was behind my 250 so im guessing its for a 164T wheel
