Name of this part?
Discussion in 'Technical' started by Mlover, Mar 2, 2016.
  1. Mlover
    Mlover Member
    Bay Area
    Ford Maverick 1974
    I recently had a bad experience while driving, my car lost control for a split second as if I had gotten a flat tire. After inspection I noticed that the nut and washers of this piece fell off causing my car's passenger front tire to be out of place. Does anyone know the name of this part? and where would be the best place to look for a replacement part? I live in the Nor California area. Thank you in advance for your help.
    The first two pictures are of the place where the nut fell off and the bar it was attached to and the last picture if the other side which still has it
    12799306_10207394991047658_5248917383425227534_n.jpg 12803231_10207394994127735_4736299990989037544_n.jpg 12803211_10207394993527720_3532018657914429539_n.jpg
  2. jasonwthompson
    jasonwthompson Member
    Carrollton TX
    That is the strut rod. It appears you are missing part of the strut rod bushings on that side. There is a front and rear set on each side, I believe they come together as a set.
  3. 71maverick361
    71maverick361 Vern Isaac
    Odem
    71 Grabber
    X2 Jason is correct
  4. tody
    tody Member
    cologne, germany
    and if you get replacements, get a Moog brand set.
  5. mav1970
    It holds your lower control arm solidly in place - worn out, it will be hard to hold a front end alignment
  6. Craig Selvey
    Wow....those nuts don't just "fall off". :huh:
  7. 71gold
    yep...someone was screwing with that nut...:yup:
    you would have noticed it coming loose a long time ago...:slap:
