Need advice about old oil...
Discussion in 'Technical' started by Pasc, Jun 10, 2007.
  1. Pasc
    Quebec, Qc
    76 Stallion
    Yesterday me and my dad were able to start the Stallion and it run for more than 1/2 seconds. The fuel filter was clogged and since we dont trust the fuel line, we used an home made canister plugged into the fuel pump and the engine now run on his own. We dont know if the car move, but that's another story. ;)
    We need your advice about old motor oil. The Stallion didn't run for maybe 3 years (maybe more, maybe less we dont know). We checked the oil and its black. What do you suggest? Can we change the oil/filter right now? Should we run the car for some time and change the oil/filter after that? Should we run the car with some additive before changing the oil? Since i had bad experience with an old tillers and old oil (long story) we dont want to blow the engine and we need your advice.
    thanks!
  2. Rick Book
    Rick Book Member
    Thailand
    Missing my old '70 Maverick
    Personally, I wouldn't hesitate to change the oil and filter. The cost and hassle isn't that much (relative to rebuilding the engine).
  3. PINKY
    PINKY .....John Ford.....
    Louisville, Ky.
    1970 Ford Maverick
    I would change the oil/filter right now (cheap stuff) while you are trying to get it running and back to a good safe street car(assuming that will mean lots of idling in the garage/driveway) . Then before I started driving it, I would change it again. Then after about 1,000 miles I would do it again; after that just do the regular schedule oil/filter change.
  4. maverick1970
    maverick1970 MCG State Rep
    Missouri
    Like they said, I would change it now.
  5. 71gold
    ...cheap oil and filter... for the startup and then go to the good stuff when ready for the road.. :yup:
    ...:bouncy: ...
  6. mcknight77
    mcknight77 Member
    Boise, ID
    74 Mav drag car, 1970 Maverick, 1971 Bronco, 66 Nova, 67 Ranchero
    Changing the oil and filter is never a bad thing. (y)
  7. hotrod-daddy
    hotrod-daddy Member
    Rock Springs,Wyoming
    a 1971 Grabber with a 302/351
    (y)
  8. Max Power
    Max Power Vintage Ford Mafia
    St. Paul, MN
    New oil > old oil.
    A no-brainer.
  9. ratio411
    ratio411 Member
    Pensacola
    1972 Sprint and 1975 Maverick
    I agree with the 'change it cheap' crowd.
    Get it running well before using any expensive oil or filters.
    That will also help it clean itself up.
    Add a little ATF to the new oil if you like. It's just a high detergent engine oil. Will help clean things up too.
  10. jmgford
    jmgford Member
    Iowa
    Ratio is right on about using some ATF. I worked at the dealership for 20 years and we did this many times to revive some cars that had been badly neglected.
  11. dkstuck
    dkstuck Member
    Latrobe Pa (Pgh)
    72 Maverick in drag
    I like the motorcraft filter. Warm up, drain, cheap oil an motorcraft filter. Run a hour an change again. See how oil looks then. Good luck
  12. Pasc
    Quebec, Qc
    76 Stallion
    Thanks everybody for all your advice! (y)
    We were affraid that putting brand new oil in an engine that hasn't ran for a very long period of time could blow it!
    I did that on an old tiller i had and i blew the engine. That's why i was asking if we could damage the engine. We dont want to blow the engine so we will mix all your advice and change the oil.
  13. don graham
    somehow i doubt the new oil was the reason the tiller blew. it was probably ready to do so anyway. new oil and filter will not harm an engine in any way. :)
  14. 71gold
    ...check when you drain the old oil and see if it has ...sludge...in it. if so you might want to drop the pan and clean the ...pickup screen. :yup:
    ...:bouncy: ...
  15. Jay.....
    Jay..... Many Mighty Mavericks!
    Mount Prospect, Illinois
    71 302 w/ a/c-- 71 200 3 on the tree!
    how much is a little ATF...?
    A couple ozs. or a quart? :huh:
