Need ball joint help!
Discussion in 'Technical' started by Racer_X, Aug 2, 2010.
  1. Racer_X
    Racer_X Maverick Hugger
    North Carolina
    1974 Maverick (1970 clone)
    How do i remove my lower ball joints?
  2. rickm
    rickm Member
    Owosso Mi
    You mean the riveted ones ? Get an air chisel, thats what I did on my Mustang. It poped them right off:thumbs2:
  3. Dave B
    They are either pressed, or welded to the lower control arm. Usually it's replaced as a complete unit.
  4. Racer_X
    North Carolina
    they look riveted. duno why ford would rivet them in but anyway. i plan to bolt the new ones in once i get the old ones out
  5. Bob Wiken
    Fayetteville, Arkansas
    I just checked Auto Zone , they only sell wgole control arm. $41
    Duralast/Ball Joint - Lower
    Part Number:
    FA1020
    Price:
    $41.99
    Warranty:
    Limited Lifetime
    Notes:
    Arm & joint
    STORE PICK UP
    SPECIAL ORDER
    SHIP TO HOME
    AVAILABLE
  6. RMiller
    RMiller My name is Rick
    Kennewick, WA
    1971 Maverick Grabber
    That's the way GM did it on the uppers, with rivits. Usually the replacement comes with bolts for installation.
  7. bmcdaniel
    The lower arms are "just along for the ride", they don't have much of a load on them as the car is supported on the uppers. When the lower ball joint finally does go bad the bushing usually isn't too far behind so the whole assembly should be replaced.
  8. rthomas771
    16 rivets are a lot cheaper than 16 nuts, bolts and lock washers. Take than number and multiply by millions and you can figure out how much the auto makes save a year on mounting ball joints to a control arm.
  9. sgaugeguy
    sgaugeguy Bob Kraus
    WILLIAMSTOWN NJ
    Buy MOOG Chassis parts! Part number is K8123 I found mine for $45.00 each.
  10. blugene
    I have never seen or found just the ball joint. Easy to do the complete arm..
  11. soooulpower
    Mapleton Depot, Pennsylvania
    Ball joints are a must do on my list. Good to see this thread.
  12. Racer_X
    North Carolina
    i give up, damaged one of my control arms tryn to get tha balljoint off. gonna just order tha whole unit for both sides
  13. justin has a 74
    kentucky
    Oh come on. If i can do it you can do it. It took me 2 hours but its possible.
  14. Racer_X
    North Carolina
    nah i managed to chizle a hole through it lol. used hand chizle my dads air hammers dont work.
