need diagnostic help
Discussion in 'Drag Racing' started by nastynickel, May 13, 2008.
  1. nastynickel
    nastynickel gearhead car junkie
    Portorchard, WA
    1972 grabber mav
    OK guys heres the skinny. I've been running my maverick at the strip for a few passes now and ran a best et. of 13.85 after doing the 3.8 taurus fan swap. The car was shifted at 5k with no problems. Then a few ford guys said that we were shifting too soon and should shift it at 55-56k and should lose .5 tenth on my et. Now here is my problem, at approx 5300 rpm the car falls flat on its face, coughin and sputtering. It did this at both the 1-2 shift and the 2-3 shift ( with a C4 ). This is weird cuz a 302 should rev to about 6200 with out any problems ( even when stock ). I have an ACCEL distributor with ACCEL super coil wired into the stock wiring ( no box ). I have a HOLLEY red fuel pump and a Fram fuel filter. The carb is an EDELBROCK 600 cfm on WEIND intake. Any sugestions on where to look first? I dont want to chase this and replace things not needed. I will replace everything if that is what it takes but dont want to unless neccasary. :hmmm:
  2. PINKY
    PINKY .....John Ford.....
    Louisville, Ky.
    1970 Ford Maverick
    your either running out of timing.....or fuel :)
  3. yellow75
    Tillamook Oregon
    13.85 is darn good for a stock 302, how many miles on the motor? With you revving that high on a stock motor you might be getting into a valve float issue.
    You could try bumping your timing up a little and see if it helps but it does sound like you are running out of fuel, make sure fuel filter is good.
  4. bossmav
    bossmav Drag racing nut
    Harrisonburg, Va
    74 Grabber now Pearl white
    You need to play.
    I agree with Maverick5946, it's one of the two.
    For racing I would set your timing to 28 degree at 2000 rpm this might be a little high but you could adjust one way or the other.
    If you are still running the 5/16 standard fuel line from your tank then it's a good chance you are running out of fuel and maybe fuel pump.
    NOW DO THIS! Change one thing at a time, and see if that helped or not.
    Good luck and keep everyone posted.
    Bossmav
  5. PINKY
    Louisville, Ky.
    1970 Ford Maverick
    one other thing you might try.....check the plugs while it is running (at night) it needs to be dark....I once had a miss at higher rpm's. Took me till nightfall to figure out what was wrong :oops: ended up one of the plugs was/where cracked around the ceramic area. :) and it was jumping out the boot....when it was dark I could see it. :cool:
    But I would still guess its timing or fuel.
  6. blugene
    Just a question cause I don't know... Would a dyno help locate the problem(s)?
  7. bossmav
    Harrisonburg, Va
    I think that's a outstanding question!
    It would show if the timing or a mis-fire was the problem, even if the fuel was the cause. The dyno fuel system would not be restricted. Now that is if the engine was out of the car and in a speed shop.
    A rear wheel dyno would help but may not tell the hole story.
    I like that type of (out of the box) thinking, way to go Gene!
    Bossmav
  8. bjcman
    bjcman New Member
    Santa Rosa Beach
    1977 Mavrick
    Seems to me, in the case of a bad plug or wire, u wld not need to rev to 5300r's before it came into play...The timing or gas...or both...
  9. blugene
    I'm leaning to valves floating...keep us posted.
  10. PINKY
    Louisville, Ky.
    1970 Ford Maverick
    I would definitely have to disagree with you!
    It happened to me, so that of which I speak I know to be true.
  11. ratio411
    ratio411 Member
    Pensacola
    1972 Sprint and 1975 Maverick
    There are very good ideas here, but if I was to pick one...
    I am on the "valve float" bandwagon.
    Weak valvesprings...
  12. wero
    wero Member
    I use to have some thing like that, try taking out the hood just to see if you need more air if you do is time to put a scoop or ram air or something,,, good luck
  13. wero
    wero Member
    check your camshaft ... the card specs...... is your camshaft is designed for that rpms?
  14. ratio411
    ratio411 Member
    Pensacola
    You're joking.
    Right??? :hmmm:
    A stock cam will turn 5500 rpm with good valvesprings.
    :stirthepot:
  15. mavman
    mavman Member
    Arkansas
    Heck they'll go 6500....but will it be making any power? I think not. I agree...13.85 on a stock 302--that is great! Faster than half of the factory "muscle" cars (mustang, firechicken etc.)
