need help asap!!! running too rich
Discussion in 'Technical' started by mavgirl78, Oct 10, 2009.
  1. mavgirl78
    mavgirl78 New Member
    waco tx.
    74 maverick
    the 74 is running too rich. when i start it up it does good but after about a min it starts too run super rich and black smoke start pouring out of the exhaust. what do i do please help what should i set all my screws and what can i do to stop the rich running. it has the carter 1 barrel carb.
  2. YellowStangDuan
    YellowStangDuan Member
    Arlington, Texas
    71 Grabber
    Make sure the screws that hold the main body to the throttle plate are tight. Just grab the top part of the carb and see if it's loose.
  3. greasemonkey
    greasemonkey Burnin corn
    Sedalia,MO
    And make sure the choke is open.
  4. baddad457
    And the float's not stuck.
