Need Help Removing Exhaust Manifold
Discussion in 'Technical' started by lpolson07, May 17, 2010.
  1. lpolson07
    lpolson07 Member
    Des Moines
    76 Maverick, 72 Comet
    Alright, I am trying to remove the stock manifold in my 76 250 and 3 of the bolts will not budge....how do I remove them?
    I didn't want to break them off so I didn't full force it....what do I do?
  2. maverick75
  3. yellow75
    Tillamook Oregon
    Exhaust bolts are always a p.i.a., I have had the best luck using a little heat on them if power blaster doesnt work, hot air gun works even a hair dryer will heat them up some.
  4. cyclonewill
    cyclonewill Member
    SandSprings, Oklahoma
    The best trick is an old man trick I heard a few years ago. Heat the bolt head cherry red with a torch, then touch it with a candle. (dont use one of the wife's- they get mad) the heat loosens it up& the wax lubricates the threads.
  5. lpolson07
    lpolson07 Member
    Des Moines
    Thanks for the tips guys....I don't have a torch or a heat gun so I will stick to the can of loosener and a hairdryer.
  6. Jsarnold
    Jsarnold Senior Member
    Raleigh, North Carolina
    '72 Sprint
