Need help with a cam please!
Discussion in 'Other Automotive Tech & Talk' started by 19MAVERICK72, Jun 29, 2014.
  1. 19MAVERICK72
    19MAVERICK72 Dan
    Houston
    1972 Ford Maverick
    Can any one please give me some advice? I have a 79 f100 with a 351w stock heads edelbrock intake with a 650cfm holly, headers and a posi with a 3:50gear i have been looking for a performance cam but i don't know what will be good. I want the sound and the extra power. I will really appreciate the help.
    thanks!
  2. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    Go with a Comp 265DEH.
  3. 71gold
    call Com Cams and ask them...:yup:
  4. groberts101
    groberts101 Member
    Minneapolis, MN
    I'd go one step(or even two) down from Larry's recommendation due to the weight of a truck with only moderate gearing and likely having a stock stall convertor.
    You SHOULD be wanting low-midrange torque without much care for a near 6,000 rpm redline because that small volume manifold is all done by a little past 5,000 rpm anyways. The motor will feel bigger and more responsive to the pedal without having to rev it to get all that weight moving. Better mileage too.
  5. dan gregory
    dan gregory Member
    chesapeake va
    1970 maverick
    Yeah,Groberts is prob. right,bigger is not always better because those hds are killing you.
