Need help with parts.
Discussion in 'Technical' started by Llamaface, Oct 29, 2015.
  1. Llamaface
    Llamaface Member
    1973 ford maverick
    Newbie here!!
    I have a 73' 6-250. I wanted to upgrade the carb, intake and distributor. I preferred from classic inclines, but I found out today they are closed. What should I upgrade to for performance?
  2. Llamaface
    Llamaface Member
    1973 ford maverick
    Also it is an automatic.
  3. Craig Selvey
    To a V-8.
    Nothing....dollar for dollar......will make more performance than upgrading to a V-8. A car, intake (no such thing on a 250-6) and a distributor will do nothing unless you do lots of other work as well.
    Shorty and Krazy Comet like this.
  4. Krazy Comet
    It'd be nice if Ford's small 6cyl had a upgradable head/intake, but in the interest of cost and the fact anyone that wanted performance bought a V8, leaves most of the the inline 6 cyl wanting... Sure there are guys that just had to show it can be done, but those are mostly re-engineered pieces with custom heads...
    Craig Selvey likes this.
  5. spdracr301
    spdracr301 Member
    Franklin NC
    1976 maverick
  6. 71Mavrk
    71Mavrk Member
    Nevada
    Everything kit does not fit the 250.
    I had a Weber set up on my 250. Had to modify the adaptor plate to correctly align the carb to the throttle cable and gain hood clearance. Air cleaner was still very tight. Had to use one with clips rather than the Weber bolt on one.
    This kit looks like it has the element but no housing.
    The headers use to drag on every speed bump.
    Performance was not worth the price. Should have just done the V8. Years later, I did.
    Micah
    spdracr301 and Craig Selvey like this.
  7. Krazy Comet
    That second kit is for the 240/300 6cyl, totally different engine than a 250, no interchangeable parts...
    First kit is for the shorter 200, probably require a cowl hood for use with 250(if not the 200 as well)...
  8. Llamaface
    Llamaface Member
    1973 ford maverick
    Thank you for all the help everybody!!! I do want to switch to a v8. But I'd rather save up for a bit and get everything crated or find one already in a maverick. The car I own is lacking power.... Badly. So, I bought the Weber 32/36, fuel regulator, 2 to 1 adapter, duraspark ii kit and distributor. I swapped out my fuel pump and radiator(had a leak) today. Hopefully she gets better. I think my issues with power may be coming from my distributor timing. Everything should get swapped out in the next two weeks. If it's not fixed.... On to compression test dun dun dunnnnnnn!
  9. spdracr301
    spdracr301 Member
    Franklin NC
    1976 maverick
    yes it does require a cowl hood to fit
  10. spdracr301
    spdracr301 Member
    Franklin NC
    1976 maverick
    LOL just did my compression test today 120 120 90 90 120 120
  11. rthomas771
    Classic Inline is still selling parts but not online, see http://fordsix.com/forum/viewtopic.php?f=103&t=73807
  12. Llamaface
    Llamaface Member
    1973 ford maverick
    You guys are awesome! Thanks for the friendliness and help everyone!!! Anyone near Pottstown pa?
  13. Llamaface
    Llamaface Member
    1973 ford maverick
    Should I switch to an electric fuel pump or stay manual?
  14. Llamaface
    Llamaface Member
    1973 ford maverick
  15. Llamaface
    Llamaface Member
    1973 ford maverick
    Look odd with cold air intakes*******
