Need help with timing for a 250 inline 6
Discussion in 'Technical' started by russellgaspard, Aug 27, 2014.
  1. russellgaspard
    russellgaspard Member
    united states
    1973 Ford Maverick 250 Inline 6
    I was timing the engine and was wondering if before I time it do I need to have the vacuum advance on the distributor disconnected while setting it. It's a 1973 250ci inline 6.
  2. mike75mav
    mike75mav Member
    Bremerton, WA
    1975 maverick 4 door; 1971 Bronco frame off restoring
    Yes, you need to disconnect the vacuum advance and plug the hose. Than you can time it at 6 degree TDC.
  3. russellgaspard
    united states
    The specs say it should be 12 degrees for a 250 inline 6
  4. mike75mav
    mike75mav Member
    Bremerton, WA
    Your right. I was going on memory bad idea.
  5. rthomas771
    Set the timing where it runs the best. I would use a vacuum gauge instead of timing light
    doncomfort likes this.
