Need Some Help
Discussion in 'Technical' started by anthonyv90, Jul 5, 2008.
  1. anthonyv90
    anthonyv90 Member
    South Los Angeles,California
    71 maverick,69 429 thunder jet T-Bird.
    yes i recently got a 71 mav. but the fuel gauge doesnt seem to work any ideas y? or what can i do to fix the problem
    :huh:
  2. 71mavkidd
    71mavkidd Member
    Kansas City, Kansas
    keep it full :hide: i have no idea but good luck
  3. PaulS
    Disconnect the wires at the tank. With the key on ground the wire. Does it move?
    With the wire dangling turn the key on does the gauge move?
    if the answer to both questions is no then you need to replace the voltage regulator behind the dash (the fuel and temp gauge should both NOT work.) If the gauge moves in either of the two tests then the sender is bad and you will need to replace it.
  4. dmhines
    dmhines Dixie Maverick Boy
    Cumming, GA
    I just went through some Fuel Gauge troubleshooting. What do you mean by not working at all? Is it always to the far left ... below E? Like Paul said above .. Pop the harness off the Fuel sending unit, unbend a paperclip and insert one end into each connector on the harness. This will be 0 resistance and your needle should jump to far Right above F with key on. If that works you know the gauge is working.
    To check the regulator use a multimeter on the harness ... the voltage should jump all over the place .. that means regulator is working. Check resistance between pins on the sending unit while you have the harness off. It should be somewhere between 78 ohms (empty) to 10 ohms (full).
    Good luck ..
  5. Mavaholic
    Mavericks dont have temperature gauges. :D The voltage regulator is only for the fuel gauge.
  6. Mavaholic
    The 70 only has one pin so you would check it to ground.
  7. dmhines
    Cumming, GA
    His post says its a 71 ... :huh:
  8. 71gold
    where ..."on the engine"...would you find this...harness...:huh:
    ...Frank...
  9. dmhines
    Cumming, GA
    Good question! Engine should be Fuel Sending unit ... (y)
  10. Mavaholic
    oops....I saw 70 under his avatar. Thats what I get for only reading every other word. :D
  11. 71gold
    You need to leave the...speed reading...to the younger folks...:yup:
    ...Frank...:outtahere:
  12. Dave B
    I read this whole post, now I'm more confused than when I started...:rolleyes:
  13. anthonyv90
    anthonyv90 Member
    i tried the paper clip in the connector but the needle didnt move to f or nothing it just stayed below the E. So what do you guys think it is?
  14. dmhines
    Cumming, GA
    Now you need to check the voltage with a multimeter ... same place you put the paperclip.
    Oh ... and you did have the key to ON when you checked it right? :)
  15. anthonyv90
    anthonyv90 Member
    yea i did have it on.
    thanx
