Need some help :)
Discussion in 'Maverick/Comet Projects' started by Csand1196, Jul 18, 2011.
  1. Csand1196
    Csand1196 Member
    Downey, California
    1972 Ford Maverick
    So today i was going to try and get the exhaust pipes off because of it being rusted and having holes on it. But the bolts were rusted on really good. I was a little nervous to put force into it. Do you guys know where would be a good safe place to set up the jacks for me to get under there? Pictures would certainly help:thumbs2:
  2. PaulS
    Jack-stands can go under the sub-frames but the jacking points are on the outside rails - look for the notch in the ridge that hangs down where the metal is joined.
    A 50/50 mix of ATF and Kerosine makes the best penetrating oil you can get but to free up rusted bolts use soapy water - it will free the bolt better than any oil or cutting fluid.
  3. lpolson07
    lpolson07 Member
    Des Moines
    76 Maverick, 72 Comet
    If you use a sawzall make sure you wear eye protection...Rusty Metal fragments in your eye aren't fun.
