Need to know how to get spedometer cable out
Discussion in 'General Maverick/Comet' started by 71maverick, Nov 11, 2007.
  1. 71maverick
    71maverick Member
    Moline, IL
    I am trying to fix the heater knobs, something in ther ebroke and i cant get them to move properly, but to get in there I have to remove the gauges. I cant seem to get the speedometer cable off, any tips, my book shows nothing.
    and im working on my spelling :D
    Thanks
    Glen
  2. 71gold
    If all you need out is the instrument panel, there are two screws holding it in at the top, one in each gauge pod. Then you'll need to reach underneath the dash and disconnect the speedometer cable from the back of the speedo. The instrument panel should then tip forward (if you have column shift, this will be a bit easier if you move the shift lever down away from the park position). Then you should be able to reach in and disconnect the wiring harness connector that runs the rest of the gauges. That's it. Good luck.
  3. mean_maverick
    to actually get the speedo cable off, somply pull the gauge cluster forward and take notice to where the speedo cable connects to the cluster. notice the white peice of plastic at the connection.... on one side of that peice of plastic you'll notice a 'tab' or place to push it in (it sticks up slightly so it's easy to notice). simply press that in and pull the cable away from the cluster. it sounds like alot but it's really simple. good luck :)
  4. 71maverick
    71maverick Member
    Moline, IL
    Thanks for the replys
    I got the piece to come out and forward, but I didnt know how to disconnect the actual cable.
    Glen
  5. Sam M.
    Sam M. Just a nobody
    Southern NJ
    Have a look at my "dash pad removal" article in the Tech Articles section of this site. It has step by step instructions and pictures that deal with disconnecting the speedometer cable.
