Needed the firing order for 1975 Ford Maverick...please help
Discussion in 'Technical' started by dannansgirl, Aug 1, 2010.
  1. dannansgirl
    dannansgirl New Member
    Texas
    1975 Ford Maverick
    Hi all. My boyfriend and I are working on a 1975 Ford Maverick that has been badly neglected and sitting out in a field for a couple years. It's going pretty well considering. What we need from you wonderfully knowledgeable car enthusiasts is the Piston Firing order. Thank you for your time and help!
    DannansGirl
  2. Mavman72
    Is it a V-8 302 0r is it a 6 cyl???
  3. dannansgirl
    Texas
    1975 Ford Maverick
    a 6 cylinder 250.
  4. Mavman72
    1-5-3-6-2-4 Is what you need...
  5. dannansgirl
    Texas
    1975 Ford Maverick
    ty is that clockwise? or counterclockwise?
  6. rthomas771
  7. mavdog71
    mavdog71 Member
    Moreno Valley, CA
    '71 Maverick Grabber
    The vaccum advance will bolt to the dizz base on right or left of center as you are looking down form the top .... If you take your finger and start on the vaccum advance can hose nipple and trace around the dizz base in a P shape if the can is on left of center it is clock wise .... if the can is right on center it is ccw.
