Neutral safety switch
Discussion in 'General Maverick/Comet' started by MonstrousMav72, Jun 2, 2018.
  1. MonstrousMav72
    MonstrousMav72 Member
    1007 N La Cadena Dr
    1972 Ford maverick 302
    Alright so I just put in a floor shifter from a late 70s mustang and my mav was a column shifter. I had to get a neutral safety switch for the trans and found my old one on the trans. Now I’m stuck trying to figure out how to connect them so I can get the reverse lights to work and the actual purpose of the neutral safety switch. Heres the switch I put on and here’s a pic of the original
  2. MonstrousMav72
    1007 N La Cadena Dr
  3. 71gold
  4. Craig Selvey
    On a factory set-up, there is a short wiring harness that goes from the trans mounted neutral safety switch, up thru the firewall, and plug in where the column mounted neutral safety switch was located.
    Maverocket likes this.
  5. Doug
    Doug Member
    washington state
    71 maverick grabber
    I know it's a pain but the factory switch on the column was controlled by levers on the transmission . The levers moved your column shifter to the neutral and reverse locations .
