new 76 maverick 250 kentucky/tenesee
Discussion in 'New Members Forum' started by danman8933, Mar 15, 2012.
  1. danman8933
    danman8933 Member
    kentucky
    76 maverick 2dr
    well i just got this maverick to use as a daily driver and fix up at the same time. i dont really know much about working on cars "yet" The car idles smooth but when i press on the gas it shakes like crazy. a friend of mine said this could be because i need to bleed the brakes but that it could also be the flexplate wich doesnt make any sense to me. what else could it be?
  2. Mad Goon
    Mad Goon Scaring the Hondas
    Redondo Beach, California
    It could be a lot of things or just one thing.. Here are some ideas:
    Tune up(distributor cap, rotor, spark plug wires, spark plugs, air filter, fuel fiter, PCV valve, oil change)
    Carburetor(rebuild or adjust)
    Drivetrain issue(bad u joints, motor mounts or a transmission mount can cause vibration)
  3. danman8933
    danman8933 Member
    kentucky
    76 maverick 2dr
    thanks knowing what to look for should help ill check what i can when im at the shop this weekend
  4. rayzorsharp
    The brakes need to be bled? Hmmm...I'm gonna go out on limb and guess that your friend repairs computers or something rather than cars for a living. :)
    I'd definitely try plugs and wires first...just a good general tuneup, and it could be carb problems too. But not brakes.
  5. blugene
    No kind of shaking requires bleeding the brakes that I am aware of lol. If it shakes when you apply the brakes then there is probobly a rotor run out problem. That means at least one brake rotor is warped.
  6. franktf
    franktf Member
    Pinellas Park, FL
    72 Mercury Comet
    :Welcome:to the site!!!!!
  7. mavgrab302
    :Welcome:from Ocala,Florida.......
  8. wardf
    wardf Ward Frahler
    Elizabethtown, Ky.
    70 maverick
    Welcome from Ky. Where are you located?
  9. Pony Express
    Pony Express Haul'in @**
    DelMarVa
    1976 Maverick
    :tiphat::Handshake:beerchug::wave::racingflag:
  10. Mercurycruizers
    Venetia, PA
    :Welcome:to the board....
  11. danman8933
    danman8933 Member
    kentucky
    76 maverick 2dr
    Fort Campbell area
  12. WeekendWarrior
    WeekendWarrior Member
    southeast georgia
    1976 ford maverick
    brakes shaking a car when you press the gas???? next thing be the tail lights causing a blow out lol.
  13. mav1970
  14. Eastern Raider
    Eastern Raider Member
    middle Ga. warner robins
    Does the engine shake, or the body,when you accelerate? :tiphat::16suspect :chirp::chirp:
  15. danman8933
    danman8933 Member
    kentucky
    76 maverick 2dr
    Body and I am pretty sure its a transmission mount. Going to check it tomorrow the shop
