new blood 70 grabber 70 torino
Discussion in 'New Members Forum' started by edsrod, Apr 8, 2011.
  1. edsrod
    edsrod New Member
    xenia ohio
    70 grabber
    just traveling around and found this web site. thought the information was great! i do have a question ?? purchased a set of TWO carbs CARTER 4157s? was told off a 427 ford? my little research says true but was told only worth 50.00 or so as a core? thats a bit hard to swallow? looking for information ?? one response was > galixie 1964 holeman- mooney ?? thats hard to believe too and only be worth 50.00. i want to sell them and get them to the right person to use? dont want to ebay or clasify them unless i know exactly what i have and a price estimate? thanks for letting the newbee get in so easily and be a part of the maverick team. i have a 302 70 grabber and a 70 torino 351c gt torino. great [ DIFFERENT cars!! thanks everyone!!!!!!!!!!!!!!!! email to dane.oh@netzero.net if needed thanks Eddie should have been in 64 galaxie and lter motors from holman-mooney
  2. edsrod
    edsrod New Member
    xenia ohio
    70 grabber
    carter d9 4157s carbs information needed
    looking for information for these carbs for resale. i picked them both up was told 427 ford. i found out to be true but cant find a used value. i want these to go to the right person was told holeman- mooney used thes number of carbs? was told 50.00 as cores?? thanks eddie
  3. don graham
    Welcome to the board. Hope you find the info you need.:Welcome:
  4. edsrod
    edsrod New Member
    xenia ohio
    70 grabber
    any information was told 427 ford ?? worth 50.00 for cores, i have matching set of 2 . told holeman-mooney used this numberd carbs? i want to get to right person for right price?? any help?? thanks Eddie
  5. mav1970
    :Welcome:from a fellow 70 Maverick owner over in Northeast Pennsylvania
  6. franktf
    franktf Member
    Pinellas Park, FL
    72 Mercury Comet
    :Welcome:to the site!!!!!
  7. socalcomet
    socalcomet Member
    Menifee, California
    1974 Comet
    :Welcome: from Southern California
    You may want to post your question in the technical section. Not everyone will see it in the new member thread. If selling post in the parts for sale section. Have patience, someone will chime in...good luck.
  8. 65 comet
    65 comet Member
    Colorado
    65 Comet Caliente Hrdtp, 65 2+2 Mustang Fastback 4 spd 53 F100 project 67 Ford 1 ton 4x4 project
    edsrod, :Welcome: to the site from Colorado.
    As for your carbs, I am sorry to give you this info but they vary in value as builder carbs. If the venturie rod ports in the base are worn out (shafts has orbital movement) they aren't worth anything unless you can find someone that needs them for parts. If they are tight and will not suck air then you might get between $45 and $75 apiece for them if somebody is in need of them for a restoration project. They are not that scarce and not really in to much demand. The cost of rebuilding them limits the core value. The fact that Holman and Moody used them doesn't factor in to the value, as they used several parts in their builds which most of were purchased parts. What creates the value is if someone needs them because they are restoring a H&M car that had them on it. Hope this helps.
  9. edsrod
    edsrod New Member
    xenia ohio
    70 grabber
    thanks to all !!!!!!!!!!!!!!!!!
    Thank you to everyone nice welcome!!!!!!!!!!!
  10. dbailey
    dbailey New Member
    berkeley ca
    cometgt
    another new guy dbailey
    hi dbailey with no computer skills but a love for cars and a 72 cometgt
  11. dbailey
    dbailey New Member
    berkeley ca
    cometgt
    hi dbailey with no computer skills but a love for cars and a 72 cometgt ialso need a few parts where do i find parts for sale section
  12. bri
    bri midnight special
    mission city b.c. canada
    71 comet GT. 414 cu, c-4, 9+, spool 3.25, 35 spline axles, back halved,12 point,,4 whl wilwood discs, 3 link,tubbed. 73 comet sdn 302, 76 comet 2dr 6 cyl, 84 z-28 468. 98 f-150 4x4 5.4, 98 fld 120, 500 detroit. 09 jeep grand cherokee.
    welcome...
