New Exhaust Installed
Discussion in 'General Maverick/Comet' started by rthomas771, Oct 23, 2012.
  1. rthomas771
    I drove down to Macon this morning with an open header, little over 50 miles, to have new exhaust put on my 6 cylinder header. I got Harold to remove the old exhaust and install new pipes and muffler. We went with 2-1/2” out the header into a 2-1/2” inlet short turbo muffler located under the back seat area. Harold made a 2” fork coming out of the 2-1/2” outlet. Both 2" tail pipes go over the rear axle and the Right pipe exits behind the rear tire. The Left pipe runs between the rear end housing and gas tank then 90’s back and exits behind the rear tire. It doesn’t sound like a V8 but it also doesn’t sound 6 cylinder either...it got its own sound. Going down the road it kinda reminds me of an old inboard boat from the early 60’s with a little bit of flat head V8 mixed into the sound. Here's a short video of the sound. http://1bad6t.com//media/6cylExh.mp4 you might have to "Save target As" to you computer to get it to play if it doesn't play.
    [​IMG] [​IMG] [​IMG]
  2. Joe Dirt
    Looks good jeff, how does it run out?
  3. simple man
    simple man Member
    Bunnell,Florida
    That sounds great! Mine is stock quiet. That may change now! :thumbs2:
    What was the entire cost, including the header without the coating? I'm looking at a new exhaust sometime as I have just been patching things. I really want a single pipe header, but My God, they're so expensive! :)
  4. rthomas771
    Like this...
    [​IMG] [​IMG]
  5. rthomas771
    So far I have $275 invested without the ceramic coating.
  6. Joe Dirt
    Look good, i meant power wise
  7. rthomas771
    It seems to be a lot better across the board. Mid to high comes in really stronger. Gotta remember I replaced a 1-7/8" pipe and added the header at the same time. I didn't play this morning in traffic with open exhaust, also the timing and carb needed adjusted badly. Took half a tank when it should took less than a 1/8th to drive to Macon
  8. 74LDO
    74LDO Member
    Ohio
    1974 Maverick LDO
    sound
    wow thats a great sound for a six....sixes can sound kinda funny through typical hot rod exhaust. Looks like your exhaust man is a talented pipe bender.
  9. mrmalina99
    mrmalina99 Member
    Belfair, WA
    1973 Maverick
    Sounds good.
  10. Paul Masson
    1971 Grabber
    I have to admit, I was skeptical :sorry: when I first clicked on your MP4, but I am really impressed!:thumbs2: It sounds really good! Your exhaust guy did some nice clean work, too. Do you get any "really bad" interior resonnance at cruising speeds?
  11. predfan2001
    I like the way they kicked it up over the parking brake cable. Mine is rubbing.
  12. darren
    Usually 6 cylinders sound awful to me. The odd one sounds good. Yours sounds great for a six.
  13. rthomas771
    I was surprised as much as you with the outcome of the sound. The resonance is very reasonable level and not annoying at all
  14. Earl Branham
    Lugoff, SC
    Sounds really nice, be glad to hear it in person.
  15. Hawkco
    Hawkco Genuine Car Nut
    Rex, Georgia (GA)
    77 Maverick
    Sounds great! Sounds better than that one six-banger we heard one time with a Flowmaster 44 on it. Earl said it best when he said, "Sounds like an elephant farting."
    I may have to steal that muffler idea.
