new front and rear sway bars?
Discussion in 'Technical' started by random hero, Feb 17, 2009.
  1. random hero
    random hero 1972 ford maverick I6
    hudson valley
    1972 maverick
    do new sway bars in the front and rear help handling and body roll a lot. i'm getting my tax return and wanna get the most bang for my buck...if there definitely worth the money i'll get them...thanx in advance :bananaman:bananaman:bananaman
  2. Bryant
    they defintly help out with body roll and handling
  3. Craig Selvey
    If you don't have them yet....get front disc brakes FIRST!!
  4. PaulS
    The sway bars (get them in a set) will keep the car from leaning through the corners.
    They put more load on the tires which make the car handle better. To add to the suspension the next steps would be heavy duty 50/50 shocks (unless you drag race) and the "Shelby Drop" performed on your upper control arm mount)
    If you have difficulty with your brakes then a disk conversion would be the natural step.
  5. 302mav76
    302mav76 Isaac Serna
    Monterrey, Nuevo Leon, Mexico
    '76 Maverick
    Are those swaybars you talk about made by ADDCO?:huh:
  6. jayman
    jayman Member
    San Diego, Ca
    69.5 Maverick/72 Grabber
    Yes. As far as I know, ADDCO is the only manufacturer of sway bars for Mavericks and Comets.
  7. krelboyne
    krelboyne Remember
    Salem, Oregon
    15/16" front sway bars are easy to find used.
    $12-15 at U-Pullit Junk yards.
    Many Granada and Monarch cars had the 15/16" front sway bars.
    They Front sway bars are all the same for years on Ford and Mercury.
    The only problem is when you get into the big block cars with Mustang and Cougars. Certain ones rub on the harmonic balancer.
