New here and need some help
Discussion in 'New Members Forum' started by BatKing, Oct 15, 2016.
  1. BatKing
    BatKing Member
    Virginia
    73 maverick
    Hello everyone I just bought my first 73maverick and I already love her the only problem so far is my wife is giving me a little grief on the lap seat belt I was wondering if any one can help me on a way to convert it to a 3 point. It already has the mounts near the windows I just don't know what to use to change it back.
  2. Red1972Grabber
    Northern California
    Welcome from Northern California!:chirp:
  3. BatKing
    BatKing Member
    Virginia
    73 maverick
    Thank you I'm pretty new to forums so I appreciate the greeting
  4. HadaGrabberonce
    HadaGrabberonce Member
    Talcott WV
    1973 Maverick 302 C4 3.55 Tractionlok Granada disc brake conversion Small front bumper
    Take a look at seatbeltsplus.com. They have the retractable 3 points belts for about $65.00 per side. I got mine at Julianos but they were more expensive. Fairly easy install and big improvement.
  5. franktf
    franktf Member
    Pinellas Park, FL
    72 Mercury Comet
    :Welcome:to the site!!!!!
  6. 71gold
  7. z28th1s
    Lynchburg, VA
    :Welcome: from central VA!
  8. racing ranger
    racing ranger Member Supporting Member
    Iowa
    72 Comet GT Boss Powered, 83 Ranger S/G, 94 F250 Styleside 4x4, 2007 Ford Focus SES
    :Welcome: from Iowa I purchased a set on Ebay for my 72 Comet GT
  9. stumanchu
    stumanchu Stuart
    Portland, OR
    Welcome from Portland, OR.
  10. Craig Selvey
    Your factory shoulder belts have been cut/removed. That is all you really need to complete the existing system.
  11. 71maverick361
    71maverick361 Vern Isaac
    Odem
    71 Grabber
    Welcome to the Forum!!
  12. mav1970
  13. Paul Masson
    1971 Grabber
    :Welcome: from Atlantic Canada!
  14. gregmaverick
    gregmaverick Member
    Salem, OR
    1970 maverick
    I bought my seat belts here:
    http://stores.streetrodshop.com/seat-belts/
    I replaced the original "fixed" 3-point with a 3-point retractable. Using a ruler, protractor, and plumb-bob to locate a slot on the rear side moldings, and then removed them to cut. I mounted the retract mechanisms to the floor - using the the flat washer detailed in the attached PDF.
    With the car level, I hung the plumb-bob from the pillar mount to get a center-line on the plastic molding. I removed the molding, and then lowered the plumb-bob to the floor, to locate the center of the retract mechanism. After centering the mechanism, and ensuring that it won't rub against the plastic molding (seat-side) or the frame, I located mounting holes.
    For the slot, I outlined an appropriate width/length and then cut them out with a hot exact o-knife. I also made out of plexiglass, a couple of escutcheons. (Rectangle pieces with slot that screw into the molding to give it a professional look).
  15. HadaGrabberonce
    Talcott WV
    73 models were equipped with a folding shoulder harness. It is just a simple bolt on operation with the 3 point retractable.
