New IL6 installed...Still overheating!?
Discussion in 'Technical' started by Comet4me, Dec 31, 2013.
  1. Comet4me
    Comet4me Member
    1975 Comet
    Well as some of you may know, my "old and busted" IL6 was overheating and in very sad shape. So....I replaced the old ticker with a brand new remanned engine, and added ALL new bolt on parts such as; new dual core aluminum radiator and hoses, rebuilt carb, coil, distributor, plugs, wires, oil pump, new ceramic coated dual headers, and a true dual stainless steel exhaust with high flow cats. Nothing was repurposed from old engine other than starter, alternator, power steering pump and some nut and bolts. (Probably other stuff I can't remember right now) And guess what...the NEW engine is overheating!!! My best guess is a bad tranny. I have an a/t C-4 that is slipping in second gear (?) and I've not replaced those hard line either. I figure maybe it is the cause of my engine overheating. It is the only variable left I think. I figure it is robbing the engine of cool water by working harder and circulating hot water back into the engine. Any takers on this theory???
  2. rwbrooks50
    rwbrooks50 Member
    Forney Texas
    71 Maverick & 63 Ranchero
    I think that is possible. I had a Winstar van back in the early 90's that overheated when the trans under a load. It never leaked water.
    Rick
  3. Krazy Comet
    Unless the trans is requiring grossly excessive power to rotate, that isn't your problem...
    You can disconnect the two trans lines from the radiator, then connect them together with a piece of hose to test your theory, but I'll bet you are full of hot water(pun intended)...
  4. Comet4me
    Comet4me Member
    1975 Comet
    @Krazy: Well as soon as I can I'll get out there and try that. But really, if not that then what??
  5. Comet4me
    Comet4me Member
    1975 Comet
    Oh I should mention, my fluid level is low (radiator) but no puddles in driveway. I checked the oil for antifreeze but it's clean.
    But again...new engine, same old overheating problem. Just seems weird to me that I'd have two bad engines in a row. Any other thoughts?
  6. YellowStangDuan
    YellowStangDuan Member
    Arlington, Texas
    71 Grabber
    Got a good fan shroud? What thermostat did you use? How hot is it?
  7. Krazy Comet
    How hot does it run??? If it isn't pushing out coolant the engine may be a little stiff and problem will subside after a few runs...
    A few things to consider though
    The radiator should be full to rule out any possibility of overheating due to air pockets in the head... Sometimes trapped air can be difficult to remove, but if the vehicle nose is high(as on ramps) and allowed to idle till the water is circulating any air pocket should be bled out...
    Otherwise you're looking at either poor circulation(defective pump, collapsed hose etc), insufficient flow across the rad(have a shroud?) or maybe undersized radiator(guessing this isn't your problem)...
  8. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    Probably air in the cooling system.
    I can't believe you did all that and didn't swap in a V-8. The cost would not have been much more.
  9. Comet4me
    Comet4me Member
    1975 Comet
    Rad is big enough. I don't remember the T-stat temp, but it is a stock replacement. I don't have a shroud. It was at 240 degrees when I noticed it. Was no steam during overheat, the light came on and I shut it down. Heard gurgling. No steam. Radiator was full when I started driving it. Stopped at three places within a half hour. Then the overheat.
  10. Comet4me
    Comet4me Member
    1975 Comet
    @crazy. It's my wife's car and that's what she wanted.
  11. Krazy Comet
    If it didn't push out coolant my bet is air pocket/low coolant... Often a engine will idle just fine but at speed the pump will cavatate and not pump enough to keep the engine cool...
  12. Comet4me
    Comet4me Member
    1975 Comet
    @ Krazy. Well I will need to see if that is the issue. I hope so
  13. Comet4me
    Comet4me Member
    1975 Comet
    I guess my t-stat is fried. Gotta check that out too
  14. Comet4me
    Comet4me Member
    1975 Comet
    She's got purdy mouth now at least. Lol
  15. rthomas771
    Where is your PCV valve?
