new motor start up ???
Discussion in 'Technical' started by 71gold, Mar 15, 2009.
  1. 71gold
    i have my motor in and buttoned up ready to go...everything but the washer bottle installed.
    i cranked on the engine and not a pop...:hmmm:
    could it be because the washer bottle is not installed and plugged in? is there a loop that the start wire has to go through to crank and the washer bottle plug is part of that loop? :huh:
    the motor in it before ran but the washer bottle plug was pulgged in.
    i have gas at the carb, fire at the coil and the dist. is in time...(y)
    ...and if i install the washer bottle and plug it in and it still doesn't crank...could it be a bad washer bottle plug or a leak in the bottle being the reason for still no start. if i should suspect i need a new washer bottle does anyone have one i can borrow (know good) to check and see if mine is bad?...and, how is the best way to trobleshoot a bad washer bottle?
    i hope it's the washer bottle and not something else...:yup:
    that parts car i was looking at Fri. had a washer bottle on it that looked pretty good, i should have gotten it. i will pull all of them from now on..:yup:
    i can take some pics. of where the washer bottle will be mounted if anyone needs them to help with this.
    ...thanks for any help or comments...:Handshake
    Yo Friend Frank...
  2. yellow75
    Tillamook Oregon
    I vote it is something else, washer bottle unplugged is not going to keep the car from starting. How about neutral safety switch or starter wire
  3. 1970mavinator
    1970mavinator Member
    Ruskin, FL
    1970 2dr I6 maverick
    I dont even have a washer bottle in my car frank.:huh:
    Not sure if it matters that I have an inline or not.
  4. markso125
    markso125 Member
    Lewiston Ut
    1972 maverick 2 door LDO
    my first thought was distributor 180 out but you know what it might just be the washer bottle :thumbs2:
  5. rthomas771
    If the washer bottle is leaking then it could also be leaking voltage to the pushrod bearings and shorting everything out. My nextdoor neighbor's uncle's son-inlaw mothers sister had a car that had the same problem
  6. mavdog71
    mavdog71 Member
    Moreno Valley, CA
    '71 Maverick Grabber
    Frank
    ya don't need the damn washer bottle installed or plug in just take old rusty paper clip and jump the pump plug.
    jay
  7. Mavman72
    If you have fuel and spark...it should run...unless you are doing this in a vacuum.Is the rotor good...is the cap good.How about the plugs themselves????(they may be wet with fuel from trying to start the engine)its possible your ingnition systems module/MSD box what ever you are useing may be at fault.The washer bottle pump is not in the start/run circuit...its on the accessory circuit...so it isnt the problem.Hope this helps you frank...Good luck!!!
  8. Andysutt
    Andysutt '72 Comet GT
    Conway Arkansas
    1972 Comet GT
    I bet it's the washer bottle actually.
    My motorcycle didn't run worth a crap til I installed one, and then it would FLY!
  9. Bryant
    the washer bottle could be causing a polarshift in the flow of engery in the field of the power that is corsing through the design of the system that dictates the life of the beast.
    or it could have nothing to do with the motor not starting. usually ignition timing is wrong if it wont start when you have spark and fuel. unless you forgot to put something important in the motor like the pistons, or cam, or crank, or rods, or motor.
  10. don graham
    Take it back to Summit. And think it over at Baby Janes. I know you'll like that idea. :D
  11. CornedBeef4.6L
    CornedBeef4.6L no longer here
    no longer here
    The best way to diagnosis a bad washer bottle (I found) is the twelve step approach
    Step 1. Go to store buy a 24 pack of the nastiest beer you can stand
    Step 2. Start drinking/chugging as fast as you can
    Step 3. Pass out after a while
    Step 4. Wake up and pretend washer bottle is a urinal
    Step 5. Pass back out
    Step 6. Hope washer bottle is not cracked because likely you will be laying in a pool of your own piss
    Step 7. Wake up next day with a head ache
    Step 8. Check yourself and the ground under car for dampness and a bad smell
    Step 9. If it is still full plug in the electrical connector for the washer motor
    Step 10. Ask a buddy to inspect the washer nozzles
    Step 11. Hit the washer switch and give your buddy a golden shower
    Step 12. Pray like hell it starts now cuz your buddy is gonna whip your ass!!
    :D
  12. mav1970
    Do you have the correct fluid in the washer bottle? :cry:
    Also, does your license plate light work with the headlight switch in the on position? You might want to check that too. :D
  13. Dave B
    Hey! That was my question!! Can you buy the low temp stuff in Georgia?
  14. 71gold
    can you check with him and see what she did to get it to crank?
    ...:yup:...
  15. 71gold
    good idea...i'll try that...:Handshake
