just 5 days with new acrylic enamel paint dont look to bad the body not the best but need to do a lot of wet sanding not bad for a garage job paint only 100 dollors candy apple red
What kind of grit paper do you use to wet sand paint? What kind of process do you go about using when sanding your car?
Looks good...Might I suggest a soft sanding block for the wet sanding process so you dont put finger grooves in the finish...Hit it again with 2000 grit before buffing it out as well...It will have great depth and luster when your done.
