New problem...starter stays engaged for a few seconds
Discussion in 'Technical' started by scooper77515, Feb 10, 2008.
  1. scooper77515
  2. don graham
    I would try a small shim (washer) on the starter bolts and see if that helps. Just a thought.:)
  3. blugene
    I think that is a chevy remedy, some fords... I think we have the bolt it up style. If i'm not mistaken, the starter fits into a certain spot sorta like a slot. Maybe the bendex or starter shaft is bad...
  4. blugene
    Eagle transmission did this to me and it ruined my starter and flywheel.
  5. 71gold
    mine did that same thing...i had to wire it the other way...:yup:
    ...:drive:...
  6. scooper77515
    Thanks Frank, I will try that out and see if it solves the problem.
    Wish it was something OTHER than the starter. It is much easier to get to, but still a hassle with the headers and all...
  7. qicvick
    qicvick Member
    ft.worth,tx
    1972 grabber
    I have the same problem on a stock starter, old one went out, had lifetime waranty so got new replacement / plus a new silonoid ,starter would run for a second after it cranks so took it back off,Autozone cheaked it and said it was good so put it back on and drove it to store and let them hear it, they said probadlly silonoid so put my old one back on, didn't help,took new silonoid back and exchanged it , installed it , didn't help, now they say it is my switch but every thing was ok till I changed starter, I also put all new cables on it from starter to battery + and - :huh:
  8. Rick Book
    Rick Book Member
    Thailand
    Missing my old '70 Maverick
    Like Frank (and who doesn't?), when it happened to me once, "a" wire was on the wrong side of the solenoid.
  9. blugene
    Maybe ignition switch (not tumbler, but maybe) possibly going bad?
  10. lastchance
    lastchance Member
    Hingham , Massachusetts
    The starter has to be wired the way Ford did it in the later cars . If it worked the shortcut way do you think they would have wasted the money for the extra wire?
  11. revolution0
    revolution0 Member
    Washington State
    1974 250Ci Maverick
    This happened a few months back to me on my 74 (using stock starter, replaced with new one and new solenoid). I had the guys test the new starter, I tested the solenoid myself (I got a few years of electronics tech under my belt) and everything worked fine. I couldn't figure it out 'til my next door neighbor whose about 80 years old told me to get some steel wool and wd-40 and wire brush the crap out of all the contacts and to check beneath the negative/positive wire insulation for corrosion. I'll be damned if he didn't nail it on the head. Beneath the positive wiring insulation was corrosion and my contacts weren't in the best condition either. Bought some new wiring and it's been working great since. From what he said, this happens because the solenoid receives not enough voltage (either from dirty contacts or corroded wires)... I've done electronics for years and never heard of such a thing, but he was right! You'll know if this is the case just eyeballing it ;)
  12. PINKY
    PINKY .....John Ford.....
    Louisville, Ky.
    1970 Ford Maverick
    I think that only works for us drag racer :oops:
    I have mine shimmed.....:hmmm: but I am sure its not supposed to be.....:D
    Autozone/Pepboys/O-reilly's carry a starter shim for a SBF.
  13. 73runabout
    73runabout Member
    Worthing, SD
    72 Maverick, 73 Turbo Pinto
    If you have your starter wired as specified in method 2 it will over run as you are describing. Please wire as shown here.
    Best regards,
    Tony Reiners
  14. scooper77515
    Cool!!! And thanks for the diagram!!!:thumbs2::Handshake
  15. PaulS
    What year did Ford put starters with mounted solenoids into Mavericks?
