New Reproduction 2-Door Water Shields Now Available:
Discussion in 'General Maverick/Comet' started by Craig Selvey, May 2, 2008.
  1. Craig Selvey
    I have been working with Auto Krafters on getting some parts reproduced. I am pleased to announce that these parts are now finished and ready for purchase:
    Two Door Water Shields: Previously Auto Krafters only had the 1973-1977 water shields. They were labeled as being used on all years, but they would only work correctly with 1973-1977. They now have the correct water shields for the early 1970-1973 doors. If you have a 1973, you use the water shield based on what arm rests you have and where your chrome door handle is located on the inside. If you have the arm rests with the chrome door handle located on the end of it, use the 1970-1973 style. If you have the chrome door handle located in the lower front corner of the door away from the arm rest, then you will need the 1973-1977 style
    1970-EARLY 1973 MAVERICK / COMET 2DR
    FAM261 $15.95
    LATE 1973-1977 MAVERICK / COMET 2DR
    FAM260 $15.95
    I have attached a picture of the 1970-Early 1973 style.
  2. Corbin Johnson
    Corbin Johnson Member
    Sonoma County, California
    Sweet! I know I'll need some of these eventually for the Sprint and Grabber. Thanks, Craig!
  3. Dave B
    Come on!!! Once again I'm a day early!!!!! after all the fuss with the curled up old paper.
  4. Craig Selvey
    You and me both!!
  5. Jean Doll
    Palmerton, PA
    Keep up the good work, Craig.(y) Have you heard anything new about the fuel sending units for '76-'77 Mavericks?
  6. Mavaholic
    Is that priced per set?
  7. Craig Selvey
    No....I need to check on that.
  8. Craig Selvey
    Yes....per set.
  9. CaptainComet
    Cool ... I know I will eventually need a pair. (y)
