NHRA gas pedal rule
Discussion in 'Drag Racing' started by mercgt73, Jan 29, 2012.
  1. mercgt73
    mercgt73 Member
    I am doing a research paper on drive-by-wire accelerator systems. Could someone please post the NHRA rule on gas pedals? (or a super discreet link to that section of handbook). I know it has to do with double return spring requirements, but I want to fact check before I use it.
    Thanks!
  2. Moneymaker 1
    Panama City Florida
    I found this......
    http://www.nhra.com/UserFiles/file/General_Regulations.pdf
    Regardless of class, each car must have a foot throttle incorporating
    a positive-acting return spring attached directly to the
    carburetor/injector throttle arm. A positive stop or override prevention
    must be used to keep linkage from passing over center and sticking
    in an open position. In addition to return springs, some means of
    manually returning the throttle to a closed position by use of the foot
    must be installed on all altered linkage systems except hydraulically
    or cable-operated systems. Per Class Requirements throttle control
    must be manually operated by driver’s foot; electronics, pneumatics,
    hydraulics, or any other device may in no way affect the initial throttle
    operation. In Super Street, Super Gas, Super Comp, and certain
    E.T. bracket classes, timed throttle stops are permitted that use
    pneumatics and or electronics to modulate the throttle after initial
    launch. Cable throttle systems permitted. NHRA-accepted hand
    controls for the physically challenged permitted. Choke cables and
    brazed or welded fittings on steel cable prohibited. No part of throttle​
    linkage may extend below framerails.
    Google is a wonderful thing.
