Nitrous is installed, how do I use it?
Discussion in 'Drag Racing' started by mashori, Feb 6, 2010.
  1. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    My nitrous kit is fully installed thanks to Bryant. I know I need to take some degrees off the timing. I am using the NOS powershot and doing a 125hp shot. I will use 91 octane. I have an arming switch in the car and the full throttle microswitch. Do I wait till I hit 2000 rpm and then hit the arming switch or should I get a window switch? I have the programmable MSD ignition 6AL-2.
  2. greasemonkey
    greasemonkey Burnin corn
    Sedalia,MO
    Id arm it and have the micro setup to turn on at W.O.T.
  3. 408w-maverick
    408w-maverick Member
    Oklahoma City
    1974 Maverick 2 door
    Window switch is the only way to go,and i never turn have my window switch set lower than 2800 rpm was told not to have it too low.
  4. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    which window switch are you guys running?
  5. scooper77515
    YES! I was wondering about that window switch. I didn't want the tires to spin off the line and was wondering if the switch is the way to go.
  6. 408w-maverick
    Oklahoma City
  7. scooper77515
    How does a progressive work with our solenoids? I assumed the solenoid was wither open or closed, and the jet controlled the hit.
    Otherwise, I like the idea of nitrous coming on at 3000 and cutting off at 6000 so it isn't still filling the manifold when I shift.
  8. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
  9. my70mav
    my70mav Member
    Elk Grove,ca
    69.5 maverick
  10. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    yea I couldn't find anything that says my box will do the window switch function. I figure I need to purchase one.
  11. 408w-maverick
    Oklahoma City
    I know alot of guys who run the ceaper msd switch's,the only reason i have that one is i got it from a friend for $40 still in the box.
  12. svopro
    svopro Member
    Rochester Hills, Michigan
    Are you running slicks or street tires ????
  13. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    street tires, don't think there is enough juice in the car for slicks yet
  14. anytakers
    anytakers Member
    Wytheville VA
    1972 maverick grabber
    a progresser works by clicking the solenoids on and off realy fast while you are at WOT. It does it so fast that you dont even fill it doing it.
  15. Derek 5oComet
    Derek 5oComet Tire burner
    Welland,Ontario,Canada
    I wouldent worry too much about nitrous filing the intake on shifts expecially with a automatic trans.If it was a stick car then i would say a window switch for sure.I have a 125hp kit on my truck and i load the comvertor at 1500rpm (and have a WOT switch) when the last yellow comes on i mash it! Never had a burp,fart,or flutter.The 125 powershot has small selinoids and doesn't hit hard,it went 8 tenths faster on the spray.Oh by the way it is a stock cast piston 460 and i have put 7 bottles through it with no problems.My friends call it the "girly kit" haha.
