No air coming through front vents
Discussion in 'Technical' started by soooulpower, Sep 11, 2009.
  1. soooulpower
    Mapleton Depot, Pennsylvania
    Like it says my vents in the dash are not blowing any air out at all. The "defrost" one pointing at the windshield works but that's about it. I have A/C but it does me no good when it's like this. I should check the hoses themselves for clogs it seems, but how tough is it to do? This is something I can't get around, I know. Do i have to remove the whole dash or anything? I hope not.
  2. Craig Selvey
    You have a vacuum leak. The topic has been covered on here before. You either need a new switch or the vacuum canister under the hood is leaking.
  3. Dave B
    Yup, I have none of the vacuum hoses on my car connected to anything, and that's all I have is defrost.
  4. MoparSucks
    MoparSucks Member
    Plant City, Florida
    1974 Maverick 302
    ^^^vacuum leak^^^
  5. will8069
    will8069 Member
    Garland, TX
    1974 Comet 250 straight 6
    I have the same problem. How do you go about fixing this?
    Also, is this the vacuum canister?
  6. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    on my vacuum canister I had a leak right where the nipples attach to the the canister. Take it out and take a look at it and you'll see the hole. I used some silicone and fixed it right up.
  7. soooulpower
    I'll try that. I wasn't 100% sure if that thing was the canister or not.
