no fuel to carb
Discussion in 'General Maverick/Comet' started by perch, Jun 9, 2012.
  1. perch
    perch Member
    paragould ark
    1973 comet gt
    i finally got around to getting my comet running again. had the gas tank cleaned and coated, put new carb on, blew out fuel lines, reconneted everything put on new fuel pump and can't get it to run without pouring a trickle of gas down the throat. have all new filters and it will not prime itself. any suggestions? it is a 302 automatic 2bbl
  2. Dave B
    Fuel pump, or the inlet screen on the sending unit.
  3. Bobo Greybeard
    Bobo Greybeard Member
    Oklahoma
    73 comet, 76 ford f 150 custom
    Did you get the fuel pump under the cam or over the camshaft. It is supposed to go under the camshaft. I have seen it done a lot of times. Simple fix.
    Good luck with it.
    Bobo
  4. ESampson
    ESampson Member
    Nanaimo, BC
    1974 Comet GT
    been there done that...blew my mind until i realized it..got so mad i went and bought a block off plate and a holley electric lol....id check and see if you put it under or over.
  5. 71gold
    did you try...compressed air...in the tank?
  6. rthomas771
    I replaced two brand new "lifetime warrantyā€¯ fuel pumps in a 45 day span before I got one that would last. It seems every time I try and deal with the so called discount auto parts stores it comes back and bites me in the butt.
  7. Joe Dirt
    Sealer come loose and block the line? First thing i would check.
  8. Jsarnold
    Jsarnold Senior Member
    Raleigh, North Carolina
    '72 Sprint
    When doing the first startup, I had to return two fuel pumps to get a good one on the third try. First two wouldn't pump anything.
