No Leaky Cowl
Discussion in 'Technical' started by Beerstoreguy, May 25, 2007.
  1. Beerstoreguy
    Beerstoreguy Member
    St.Petersburg Florida
    1973 Comet
    I guess this would be one way to fix a leaking cowl.:hmmm:
  2. j miller
    Polson, Mt
    several members of the C.A.M.E.O. club have done this mod. it looks great when done well.
  3. PaulS
    Do you then pull air from the engine compartment for the vents and heater? Sounds like a good way to get CO poisoning.
  4. PINKY
    PINKY .....John Ford.....
    Louisville, Ky.
    1970 Ford Maverick
    71gold just did this not to long ago.
  5. mav1970
    I put this on my "to do" list also. I was thinking about taking the air in through the area when the water drains are. Maybe using some flexable air hose and those plastic inlet manifolds the Nascar boys use to cool their brakes and get air into the race car interior :hmmm:
  6. stmanser
    Davenport, Iowa
    just put the hoses in an area where NO fumes will come in from.
    i have my cowl fiberglassed over. i do get some fumes in the car, but i think they come in from the firewall, which has some holes i need to fix.
    i drive with the windows down, so i dont breathe it as much, but my clothes smell bad after a day of driving.
    i wish it didnt. not sure where this comes from.. the exhaust isnt leaking, so maybe it is a leaking header.. i dont know
  7. Mavaholic
    I think it looks good but it will not keep out all the water.
  8. mav1970
    Possible to pick up the clean air through some Shelby like fender vents.
  9. ford84stepside
    ford84stepside Lone Wolf
    Berry Alabama
    1947 Lincoln Zephyr Coupe
    Why even bother with getting fresh air to the heater/ac? It will cool and heat faster and better just using the cabin air. If you need to add a little fresh air, then just crack the window a bit. That's the same thing MAX or recirculate does on the AC now, close off the outside air....
