No spark....
Discussion in 'Technical' started by Maverick6714, Jun 15, 2007.
  1. Maverick6714
    Maverick6714 Member
    Northeast PA
    1970 Ford Maverick, 2004 Dodge Dakota Quad Cab, 1987 Ford Bronco
    I have been trying to get my 200 CID running and have not had any luck. First, it wasn't turning over very quick at all, so I changed the starter. Then, it turned real good. After that, I didn't get any spark on the points. I changed the coil, the points, and the condenser. I made sure to set the points correctly. Now, I am still not getting spark. Is there something I am overlooking? Any information would be more than helpful.:hmmm:
  2. ford84stepside
    ford84stepside Lone Wolf
    Berry Alabama
    1947 Lincoln Zephyr Coupe
    Have you got juice going to the coil? Could be a bad switch or broke wire...
  3. Maverick6714
    Maverick6714 Member
    Northeast PA
    Yeah, there was juice to the points even just no spark when it was turning over.
  4. hotrod-daddy
    hotrod-daddy Member
    Rock Springs,Wyoming
    a 1971 Grabber with a 302/351
    Is the distributor rotating when it cranks over?
  5. Maverick6714
    Maverick6714 Member
    Northeast PA
    Yeah, the distrubutor is rotating points are open and closing
  6. 71gold
    ...if you have a ...FORD...that is normal. :D
    ...:Handshake...
  7. PaulS
    Points are shipped with a coating that prvents oxidation. You should always burnish the point contacts with a piece of thick paper (like a matchbook cover) before you install them to cleean the coating off.
    Did you measure voltage at the contacts or at the coil? - if you measured voltage at the movable contact and you are not getting spark then your points and condenser are not properly grounded. There is a ground wire that goes from the breaker plate to the fixed contact of the points. Make sure it is there and not shorting the movable contact.
    If you get power to both sides of the coil but no spark - and the points are clean - the wire can be broken inside the insulation or at the terminal that connects to the points. Check and repair discrepancy.
