No start no power
Discussion in 'General Maverick/Comet' started by Wutend, Jul 24, 2024.
  1. Wutend
    Wutend Member
    Ohio
    74 maverick grabber
    I've developed a strange problem on my 74 mav. It was perfectly normal then I tried to start it and I get nothing. My gauges light up for a second and shut off. The dome light dims the the second I touch the key. Battery has good voltage. I tried to bypass the solenoid and nothing. It will click once and make the smallest spark. I ordered a new solenoid and voltage regulator. Hoping that will fix it.
    I tore apart the old solenoid and the side lugs have scorch marks but not too terrible. Everything else inside seemed fine. I also cleaned every ground and connector to the voltage regulator. Any ideas?
  2. TeeEl
    TeeEl Senior Member
    Colorado
    '73 Ford Maverick Resto-Mod
    Check your battery cables on both ends...
  3. Wutend
    Wutend Member
    Ohio
    74 maverick grabber
    I've checked both and all the grounds and fuses. Everything seems fine.
  4. Krazy Comet
    Zero chance a voltage regulator will fix it.
    You're losing ability to carry heavy current.
    Suspect components are battery, cables, their connections and the solenoid.
    TeeEl likes this.
  5. Wutend
    Wutend Member
    Ohio
    74 maverick grabber
    My bet is the solenoid just died then. Everything else seems to be in order. I tried to start the car from the solenoid and nothing happens. Barely even a singular click or sparks.
  6. Craig Selvey
    I suspect your battery. It takes more than "volts" to start a car. It may read "good voltage" and still be defective. Take your battery to a battery store and have them load test it.
    Ronald Hopkins, Krazy Comet and TeeEl like this.
  7. Krazy Comet
    The IVR produces a pulsing voltage that averages out to 5v.
    When working properly, produces on off voltage approx once a second.
  8. TeeEl
    TeeEl Senior Member
    Colorado
    Wouldn't that be AC ?...
  9. Krazy Comet
    No just pulsating DC, zero to 12v and back to zero.
    All the circuit is doing is heating a bimetal strip inside gauge. Constant voltage would overheat gauge.
    12 vac is zero to 12v positive, back to zero, then swings to 12v negative and repeat. With house current, happen 60 times a second. Can be any frequency actually, most of Europe uses 50 cycle current.
  10. TeeEl
    TeeEl Senior Member
    Colorado
    I'm not so sure about that. Isn't a half-wave rectifier just zero to V+ and back to zero?
    An ignition coil would never achieve inductance & fire a spark plug with 12V DC. It has to be "changing DC" (back & forth from 0v to 12v) which is "seen" as alternating current...
  11. Krazy Comet
    Nope, an example of alternating current is +12v, 0, -12v, 0, +12v, 0, -12v, etc etc. Before the diodes in your alternator rectify the voltage, that's exactly what's happening.
    TeeEl likes this.
  12. Wutend
    Wutend Member
    Ohio
    74 maverick grabber
    Problem was the battery positive cable decided to short itself out internally. tore it apart and the inside was cooked. Replaced it and everything returned to normal. I was testing the starter solenoid and was getting like 1v at the solenoid but 12v at the battery so that's how I figured it out.
    Ronald Hopkins likes this.
  13. TeeEl
    TeeEl Senior Member
    Colorado
    :thumbs2:
  14. Krazy Comet
    Glad you found it but short out isn't what happened. More likely acid creeped into terminal and corroded to point it could no longer carry the current demand. At that point it remaining strands burned in two.
    mojo and TeeEl like this.
  15. Ronald Hopkins
    Ronald Hopkins Member Supporting Member
    Morristown Tennessee
    1972 Comet GT
    I had the same problem wit a Ranger pickup. The positive cable going to the starter had burned almost into and it was not getting enough power to start. I took a remote starter cable and ran it from the battery to the starter and it started every time. replaced the cable. Everyone with a no start should remember it.
