non A/c heater core
Discussion in 'Technical' started by zach@zachcam.co, Jan 9, 2004.
  1. zach@zachcam.co
    zach@zachcam.co New Member
    Tn
    1974 maverick factory 6 cyl V8 now
    i need to know how to install a new heater core and take the old one out of my 74 maverick and need help on installing the heting ducts that carry the warm air to the vents if you can help it would be nice also will the ducts from a 73 fit a 74 they are suare like 74 and what year did they change the style befor 1974? Thanks
  2. 71gold
    zach, go to (search) and put in hearter core. it will bring up a lot of info. on how it is done...frank...:bananaman :bananaman
  3. Russ
    Russ Found On Russ's Drive
    New Brighton PA
    74 "Bruiser" Mav-
    My 73 has round air duct work and my 74 has square.
    You should be able to put 73 duct work into a 74 if you use all of the 73's duct work. Did that make any sense? Russ
  4. Craig Selvey
    Zach called me and I helped him out.
