nos powershot system
Discussion in 'Drag Racing' started by JHodges, Dec 13, 2009.
  1. JHodges
    JHodges thumper
    Dora Alabama
    Has anyone else used it. It sprays a 125 shot and it costs under $400 so it is reasonable. It will be going on a stock ho longblock.
  2. blugene
    What is stock ho? :hmmm:
    That 100 or 125 spray is one thing I hope to have in the future.
  3. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    I Bryant has installed those before, see if he'll chime in.
  4. bmcdaniel
    I ran one for 12 or 13 years. What's your question?
  5. JHodges
    JHodges thumper
    Dora Alabama
    An HO motor out of a fox body stang. I was wondering how it worked on a basically stock motor and what your opinion of it was.
  6. bradleygt
    bradleygt Member
    grand rapids michigan
    1970 maverick
    the engine will handle it IF your fuel system is up to par and your ignition
    your best bet is to run a separate fuel system
    brad:)
  7. greasemonkey
    greasemonkey Burnin corn
    Sedalia,MO
    You certainly want to make sure that carb is working right. One good lean spot and :Ifireworks:off to the wild blue yonder.
  8. Bryant
    thats a decent system. you want to make sure your fuel pump can maintain at least 5 psi to the system when running. also you will want to retard the timeing 4 to 6 degrees. if you keep it from going lean and not going into detination youll have lots of fun with it.
  9. JHodges
    JHodges thumper
    Dora Alabama
    I will probaly run a holley red fuel pump with it. Hopefully by then I will have a good carb
  10. bmcdaniel
    I ran mine for a lot of years on a cast piston 302. I used a Jacobs Nitrous Mastermind to protect the engine, control the nitrous and timing. Used a Carter street and strip mechanical pump. The biggest PITA is having to have the bottle refilled all of the time. $5 everytime you push the button.
  11. blugene
    Heck, I bet I use $5 worth of fuel when I punch the gas pedal in my Dodge, and I barely move lol... pos 4.7 :rant2:. Could I put NOS on that? :idea:
  12. 408w-maverick
    408w-maverick Member
    Oklahoma City
    1974 Maverick 2 door
    You can put nitrous on anything last weekend i put a 75 shot on a civic with a H22 lol
  13. JHodges
    JHodges thumper
    Dora Alabama
    what kind of times did it run
  14. tim keck
    sharps chapel,Tn
    NOS solenoids suck. After a few years they need rebuilt. Mine started hanging up after about 4 years. Compucar solenoids are garunteed for life- I've got one that's probably 15 years old & still works properly. I don't even know if Compucar is still in business. But I would look into another setup besides NOS(Edelbrock/ZEX,etc). Also if you're gonna spray it, I'd stud the heads, ARP rod bolts and get some forged pistons(not those "hyperactive" ones). Follow the directions with whatever nitrous kit you get,particularly the directions about timing and fuel. A Holley red will support the nitrous system fine, run a dedicated fuel line for the system. A stock mechanical pump will support your engine as long as it's not too radical. Have fun...it's addictive.
  15. bmcdaniel
    Couldn't tell you. In the 37 years I've owned the car it's only been on a track 2 times, during Roundup. The suspension/tires aren't set up for racing, I couldn't get traction running NA much less spraying.
