Now the thing won't start
Discussion in 'General Maverick/Comet' started by KYF350, Feb 18, 2011.
  1. KYF350
    KYF350 Member
    Paducah, KY
    1972 Ford Maverick
    I just got back in the car at the gas station and the thing wouldn't start. The battery is new and I had power, so, I jumped the solenoid and the thing started. Ideas? I contacted the previous owner and he said he had never had a problem. Thanks in advance. Craig.
  2. mike75mav
    mike75mav Member
    Bremerton, WA
    1975 maverick 4 door; 1971 Bronco frame off restoring
    Sounds like a bad solenoid. If you can get it started by jumping than its a bad solenoid.
  3. KYF350
    KYF350 Member
    Paducah, KY
    1972 Ford Maverick
    Thanks for your reply, Mike. Replaced the solenoid. Still no dice. :cry:
  4. mike75mav
    mike75mav Member
    Bremerton, WA
    Check the ignition switch.
  5. KYF350
    KYF350 Member
    Paducah, KY
    1972 Ford Maverick
    Dropped the steering column. Apparently the ignition switch had loosened. Readjusted. Good. Thanks. Craig.
