Now to decide. 3.80 or 4.11
Discussion in 'General Maverick/Comet' started by 75Mav91Stang, Aug 15, 2008.
Which gear set?
  1. 3.80
    17 vote(s)
    77.3%
  2. 4.11
    5 vote(s)
    22.7%
  1. 75Mav91Stang
    75Mav91Stang Member
    Essex Fells, NJ
    1970 and 1975 Ford Maverick
    I'm having a hard time deciding between 3.80 or 4.11 gears. Its a 302 with a c-4. I don't think it will get all too much time driving on the highway, just mainly cruising around. Any input would be great.
    Also, so I get the correct posi, I need to get it for a 28 spline axle correct?
  2. CornedBeef4.6L
    CornedBeef4.6L no longer here
    no longer here
    Yes you will need 28 spline unit.....
    For me to suggest a gear I would like to know the following....
    Tire Height give me a brand and size and I can look it up...
    Also Your cam specs and engine combo in general....
  3. 75Mav91Stang
    75Mav91Stang Member
    Essex Fells, NJ
    Thank you.
    I'll get all the info for you when I get home for lunch. The wheel is a 15in but I forget the tire wall size.
    And I bought the cam so long ago that I don't know the specs anymore. I went for an aggressive Crane cam. And I don't remember where I put the cam card either. Sorry :oops: :cry:
    Edit: Engine is a 302 from an 88 Mustang. Has rpm performer II intake, 650 holley, 1.6 roller rockers, crane cam, hooker 6901, ported stock cylinder heads
  4. 75Mav91Stang
    75Mav91Stang Member
    Essex Fells, NJ
    I'm pretty sure the height was 55 or 60
  5. CornedBeef4.6L
    no longer here
    That number is not the height it is part of the aspect ratio or percentage...
    the easiest way to think of it is like this if you have a tire that
    lets say you have a 20550r15
    205 is the a measurement of the width in millimeters. the 50 would be a percentage of the side wall compare to the width.
    R stands for Radial and 15 is the inside diameter
    So I need the whole size:yup:
  6. 75Mav91Stang
    75Mav91Stang Member
    Essex Fells, NJ
    Oh ok, my fault.
    225 55 r15 from what I remember.
  7. Dan Starnes
    Dan Starnes Original owner
    West Central IL
    Had 4:11 in mine for years and years till I broke at the drag strip. Put 3:79 in it and I like them much more.
    Dan
  8. PaulS
    If your car is to be used on the street at all - go with the 3.80 gears.
  9. scooper77515
    I have 3.80 and can use it on the highway. But it is revving pretty good, and I wouldn't want to do any highway cruising at anything higher than where it is...3500-ish at 65.
    But on the streets, under 50 mph in town, I would love to have 4.11 gears.
    My tires are 255/60r15 running about 27" tall.
    So I am not voting. You need to make a decision on what rpm you want to cruise at and at what speed, then decide based on that. If you don't mind doing 4000rpm at 60 on the highway for long distances, than go 4.11, but I bet you would get tired of it soon.
  10. PINKY
    PINKY .....John Ford.....
    Louisville, Ky.
    1970 Ford Maverick
    I have 4.11's in mine now with pretty tall tire, I have cruise the interstate for a minute and that was enough.
  11. Mavaholic
    I'd go with 3:55s if your planing on sticking with the C4. If a overdrive is in the future, I'd go with the 3:80s.
  12. streetrod77
    streetrod77 Member
    Memphis,Tenn
    77 comet
    I dont know all specs but i would lean toward 3.80
  13. CornedBeef4.6L
    no longer here
    that puts you at around 25 inch tall tire....
    Personally I would put 3.55 in it....
    I had 3.40s with a 26 inch tall tire did great cruising and racin
  14. ratio411
    ratio411 Member
    Pensacola
    1972 Sprint and 1975 Maverick
    I voted 3.80s.
    The 4.11s certainly make a C4 more fun, but they make top end hellish, and your intake won't lend itself to 4.11s either. Every time I have used 4.11s, a single plane intake ran circles around even the E'brock RPM. Even the 3.80s might like a single plane better than a dual plane.:huh:
    Anyway, the C4 has a high first gear, so 4.11s are nice for response, but sometimes it's just not worth it. I drove 4.11s on the highway everyday to and from work, when gas was cheap. It's fun as long as you don't have too far to go... My commute was only about 10 miles each way, and only half that on the interstate. No big deal, even on a daily basis.
    I still vote 3.80s though. Even 3.40s/3.55s would be cool with a short tire and/or RPM dual plane.
  15. scooper77515
    After reading 5946's and ratio's responses having had experience driving 4.11s on the highway, I went ahead and voted for 3.80. Highway is not too bad with my 3.80s, but I tend to be the guy in the slow lane doing 60 in the 65, windows down, arm hanging out, enjoying the scenery and the sound of dual Flowmaster Super44s...Wish I had a radio, so I could complain about not being able to hear it over the car...:D
