Odd exhaust question
Discussion in 'Technical' started by Racer_X, Dec 23, 2012.
  1. Racer_X
    Racer_X Maverick Hugger
    North Carolina
    1974 Maverick (1970 clone)
    is it possible to run two 2.25 exhaust pipes over the passenger side of the axle? i want to use a dual in dual out muffler on my car.
  2. Dave B
    If you want to jack the rear end up, sure.
  3. rthomas771
    That was my plan but I went with this.
  4. baddad457
    You would have done better just splitting the pipe up above the axle.
  5. Dave@RACEWARE
    Dave@RACEWARE Member
    New Britain, PA
    73 Maverick Graber 72 Comet GT
    I would be love to know if this system from Pypes would work. It's on my list to do for the early Mustangs but I bet it would be really close for a Maverick.
  6. Craig Selvey
    I don't think a muffler would fit between the gas tank and the axle. Very small area on a Maverick. Not sure of the early Mustangs had more room in that area???
  7. Racer_X
    North Carolina
    there was a guy up here that had both pipes comming ou the same side, having a hard time looking for the thread, gonna take a look in the image gallery
  8. Joe Dirt
    as jeff's picture shows it is possible to run 2 pipe over the passenger side of the axle but i think anything larger then 2.25 is going to be pushing it at stock ride height
  9. Racer_X
    North Carolina
    found the guy, it was BDComet just saw his gallery photos
  10. Joe Dirt
    makes no difference over the axle though
  11. AppMaverick
    AppMaverick Member
    Raleigh, NC
    1971 Maverick 2dr
  12. Dave@RACEWARE
    New Britain, PA
    Craig I only need about 7" from the rear to the front of the tank but I think the bigger issue would be the shocks. Still would be an interesting experiment.
  13. groberts101
    groberts101 Member
    Minneapolis, MN
    I don't see what the big deal is. Might need to run slight angles shortly after coming off the mufflers.. or keep mufflers tighter to the driveshaft.. to stay between the pumpkin and the upper end of the shock.. but I have seen some similarly tunneled Ford cars(Mav's included) running around St. Paul with 3.5-4 inch over-axle exhausts and have plenty of room to spare.
    If you really want them tight?.. just come off the dual outlet muffler with slight inward radii to merge and buddy them up with tack welds.
    Why all the hubub to get 2 pipes running out the back? To split them towards each side to achieve that "dual look"?
