Oil drain plug gaskets for 302
Discussion in 'Technical' started by Maverick Dude, Jul 30, 2022.
  1. Maverick Dude
    Maverick Dude Member
    Cranbrook, BC Canada
    The existing plastic oil drain plug gasket for my stock 49 year old pan was looking pretty ratty and I replaced it with a fiber one. It leaked, and I’d like to check if anyone has found some on Amazon that worked well. Any suggestions? Thanks.
  2. RMiller
    RMiller My name is Rick
    Kennewick, WA
    1971 Maverick Grabber
    Any auto parts store will have them.
  3. BruceS
    BruceS Member
    Texas
    1973 Comet
    Personally, I would just make one.
  4. Maverick Dude
    Here are a few shots of the oil plug, the original plastic gasket, and the new fiber gasket. I installed the plug with the fiber gasket but it is leaking with a slow drip. The plug itself seems to be one of those self threading plugs, perhaps meaning someone stripped out a plug previous to this. ( just guessing), or did all Ford oil plugs look like this. The angle of the photo makes the near left gap look larger but a four gaps are equal and travel up the height of four threads. I have some copper gaskets and nylon gaskets coming on Amazon. The local auto store didn’t have anything suitable. I set my torque wrench to 120 lb inches, (10 lb ft), I didn’t take it up to the click, but thought this is already tighter than I’ve ever torqued an oil plug, so I’ll try another gasket before I take the torque any higher.
    9D518488-CA1A-4CDF-9C8E-C3904051F3F2.jpeg 94195120-0BCB-4ACE-B11A-A166D6B6B3D0.jpeg 4A407243-CF07-4A7A-BD65-0C70A075CB6A.jpeg
  5. jasonwthompson
    jasonwthompson Member
    Carrollton TX
    Go get a magnetic drain plug with the gasket and call it a day.
    Maverick Dude likes this.
  6. Maverick Dude
    I carefully drained the fresh oil into a clean container then dropped the oil plug and re-ran it with a Dorman plastic washer with concentric ribs. I then filled the engine with the same oil. It held fine.
    F398C810-0C42-4F00-BA89-4E6942746CD7.jpeg 5A5C95F1-0356-402F-A328-09378B685A06.jpeg
  7. Krazy Comet
    Dismal Swamp
    That's a self starter, not original plug, gasket was nylon.
  8. Maverick Dude
    Yes, I imagine the pan got stripped at one point.
