oil fill cap
Discussion in 'Technical' started by 73curtis, Feb 2, 2015.
  1. 73curtis
    73curtis Member
    ohio
    does anyone know what type of gasket was used on the oil fill cap, this is on a 1972 200 valve cover,mine is just on there without one,is this how it should be or is there supposed to be a gasket.
  2. rthomas771
    They came with a thick paper gasket. It looks like the gasket was there before the ears were rivet to the cap
  3. 73curtis
    73curtis Member
    ohio
    what do you think would work to replace that
  4. Krazy Comet
    Get some gasket material and make one...
    Possibly will need to make two, cut them and slip in place, use RTV or similar to "glue" them back together... Place splits at 180* apart...
  5. doncomfort
    chillicothe oh
    I cut a thin cross section of radiator hose. Worked real well.
  6. 73curtis
    73curtis Member
    ohio
    I ended up using cork gasket material, thanks for everyone s opinions
