oil leaking in odd place '85 5.0
Discussion in 'Technical' started by garrettmuir1227, Oct 28, 2014.
  1. garrettmuir1227
    garrettmuir1227 (Almost) Certified to Work on Your Porsche
    Temecula,CA
    1974 Mercury Comet (small bumper Mav converted) 2009 Mustang Bullitt #5834
    hi my Mav has been leaking oil for a long time, since i put the 5.0 in it. I've done oil pan gasket time and time again to no avail. so today i decided to crawl under there with the engine running to see where its leaking. well ill be darned! there is a crescent shaped cut out of the block and a hole in there. its been squirting oil this whole time... i have attached a pic of this spot. does anyone know what this was used for? and how do i plug it? it seems to be there from the factory (not a hole broken through the block) was it for a dipstick? is it threaded? if anyone knows it'll help me immensely. thank you ahead of time
  2. MaverickDan
    Midlothian, VA.
    73 Maverick 4dr
    If it's on the driver's side it's where the dip stick went. You can get a plug that will hammer in, tap the hole and put a plug in it, or use a small piece of dip stick filled with epoxy. I went with the last option as it was the easiest. Been holding fine for me for years.
  3. 71Mavrk
    71Mavrk Member
    Nevada
    My engine builder forgot to plug mine too. I got a small freeze plug from Napa. 3/8, I think. Put some silicone around it and drove it home with a long punch.
    Micah
  4. garrettmuir1227
    Temecula,CA
    Thanks! I ended up using a vacuum plug and rtv and it seems to be working great! Thanks for the quick fix
  5. mav1970
    It didn't look round in the photo until I realized that part of it was hidden by the pan gasket. I had my builder tap and plug the original dip stick hole in my Cleveland since I was using a Canton pan and Canton uses their own stick threaded directly into the pan
  6. rotorr22
    rotorr22 Member
    Columbiana, Ohio
    I did this as well. Works great.
