Oil pan options
Discussion in 'Technical' started by jasonwthompson, Dec 6, 2012.
  1. jasonwthompson
    jasonwthompson Member
    Carrollton TX
    I wanted to put a cobra t-oil pan on the 302 in the Mav, but after looking underneath it appears nothing but the factory one will fit. Is anyone using a higher capacity pan in their Mav or Comet? If so, who made it.
    Thanks
  2. tody
    tody Member
    cologne, germany
    milodon has one that fits nicely. check summitracing for the part no...
  3. mercgt73
    Search for Miloden, Moroso and deep oil pan. (y)
  4. olerodder
    olerodder Member
    NorCal
  5. baddad457
    I have a 9 Quart pan similar to the Milodon on mine, bought it on ebay.
  6. jasonwthompson
    Carrollton TX
    Thanks guys. When I got the Mav with the 302, I never thought I would be limited as to what pan would fit this vehicle.
  7. olerodder
    olerodder Member
    NorCal
    Yes, unless you change the suspension to Mustang II/III it's almost impossible. But, you can a pan specially made for you by Canton. They used to make a stock type pan where the sump was extended down toward the ground another 3 to 4 inches.....................kind of limited.
  8. Phil UK
    Phil UK Member
    Luton, UK
    Ford Maverick Grabber
    I use a canton 15-630 but you have to modify the lower arm mounts, very quick and easy to do but there is cutting and re welding to do.
  9. olerodder
    olerodder Member
    NorCal
    Have you done this and could you share some photos?
  10. Bryant
    heres what i did to make my t sump pan fit
  11. olerodder
    olerodder Member
    NorCal
    Very nice job Bryant.............
  12. Phil UK
    Phil UK Member
    Luton, UK
    Putting the engine back in next Saturday so will post up some pictures then
