Oil viscosity
Discussion in 'Technical' started by Taxi Rob, Jan 5, 2008.
  1. Taxi Rob
    Taxi Rob Member
    San Diego, CA
    1972 Comet 200ci coupe
    I told my a-hole mechanic to put in 20-w50 and he put in 5-w30. What "bearing" will this have on my seals? He also overfilled it by a full quart. Should I just walk in and smile and punch him in the face?
  2. 71gold
    ...:hmmm: change it yourself...:huh:
    ...ILMAOD...
  3. don graham
    probably won't hurt anything. in fact, i think i'd rather have the 5-30 in mine.
  4. ShadowMaster
    ShadowMaster The Bad Guy
    The ShadowLands
    1969 1/2 Maverick
    You should change your own oil. Then again......you are in California. Are you still allowed to change your own oil in Weirdifornia or has that been outlawed as well?
    Mechanic probably did you a favor with the 5W-30 but I would double check the oil level. Too much can easily be drained if necessary.
    Or you can try and punch him in the face. Remember one thing though.....they typically have a variety of hand tools close by. Including hammers.
  5. Mavaholic
    And lawyers.
  6. Dan Starnes
    Dan Starnes Original owner
    West Central IL
    I have nothing to add. My well respected friends above have said it all.
    Dan
  7. Fish OutOfWater
    Fish OutOfWater Brian
    Long Island, NY
    I'm not sure I understand why you would want to use 20w-50 anyway? Thicker oil makes your engine work harder. You will get better mileage and performange with thinner oil. 10w-40 should be good for your 200. For extra protection, synthetic is the way to go. The extra oil in the crankcase will also cause you engine to work harder. The Chilton book says 5W-30 is recommended if the anticipated air temp will not be above 32 degrees before your next oil change. So yeah, you are going to have to punch your mechanic in the face. I personally would drain a little off and run it, and change it out earlier than later. dont enter any ralley races in Mexico:naughty:
    ..UWOYTIB..
  8. Tom Laskowski
    Tom Laskowski Member
    Bay Area,California
    (3) 71's,two V-8's and one 200 cid
    Most people are familiar with oil's viscosity rating—10W40, for example. However, very few may know that the "W" refers to "winter," not "weight." And most of us have no idea what the weight-rating numbers actually mean other than that the vehicle's manufacturer specifies a particular viscosity
  9. murphy88
    murphy88 Member
    waterloo on
    73 maverick 76comet
    take a little oil out and add a little lucus, great stuff
  10. bmcdaniel
    And who called that guy a mechanic?
    5-W30 is for use in later engines with tight bearing clearances.
