OK, now that I got it going, I need to stop. Master Cylinder suggestions?
Discussion in 'Technical' started by scooper77515, Dec 6, 2009.
  1. scooper77515
    My master cylinder has been starting to go out over the past few weeks, and now i have to pump it to stop, so, until I rebuild the brake system, I am garaged again.
    JEGS had an ad for a shiny master cylinder with adjustable proportioning valves, but I threw the magazine away and don't know what brand it was.
    I DO want it to be stainless or something so it wont eat the paint off and be a rusty crud-bucket under the hood.
    Other than that, it just needs to work.
    The one I have now is my 3rd or 4th, so rebuilds are not the issue, it needs to be new.
    I will also be adding later model mustang dual piston calipers to the front. Got to get this all done by spring.
    So, any suggestions on the master cylinder make/model?
  2. bowstick
    bowstick Member
    baton rouge
    1972 maverick 302
  3. mavdog71
    mavdog71 Member
    Moreno Valley, CA
    '71 Maverick Grabber
    Scott
    You may want to try www. abspowerbrake.com it may not be on the site but call then for more info..
    Jay
  4. Dave B
  5. scooper77515
    Any idea what size will swap into our cars?
  6. MikeG747
    MikeG747 Member
    Arkansas
    That looks good Dave! (y) Does the push rod lock in to the Master Cylinder?
  7. Dave B
    I can't really remember, but I think it does, I played with a few different length push rods, before I was happy with the pedal height.
    I'll get the number off the box, for the bore size I used. I had planned on putting disc brakes on the rear of this car, at one time, but not now.
    I'm using silicone fluid, disc's on the front, drum on the rear, and man, you can stand on this thing, and you'll stop!! I bought an adjustable proportioning valve, but never used it, stuck with the stock 73 drum/drum one.
  8. rthomas771
    1" bore works with the stock pedal ratio. 90 Ranger has the correct fittings on the shock tower side, 90 Mustang has metric fittings on the engine side of the cylinder and 25mm bore. Both have the residual valve built in.
  9. scooper77515
    silicone fluid? I will have to look that up. Hopefully easier on the paint?
  10. scooper77515
    From the website...http://www.motorcycleproject.com/motorcycle/text/cows-brakefluid.html
  11. scooper77515
    I am looking at Wilwoods at Summit. Can someone suggest a part number that will work with my car? I have no idea what size the holes are, or anything.
  12. Dave B
    So, you want me to walk out to the garage?
  13. scooper77515
  14. Dave B
    I made it half way to the garage, but stopped at the fridge for a icy cold Corona...
  15. scooper77515
    Of course not. Just pull it up on the Spec Sheet on your website...like this...http://scooper77515.fordmaverick.net/specsheet.htm
    But of course, if you don't have one of those, then sure. Walk out there.
    How deep is the snow?
