ok what is this part called?
Discussion in 'Technical' started by 4DoorMav74, May 18, 2007.
  1. 4DoorMav74
    4DoorMav74 Youngin'
    Oceanside CA
    1974 four door Maverick
    i have power steering fluid leaking from this part and need a new one i guess...it is the thing in the middle sticking out... what is it called? it is on the drivers side behind the brake
  2. Craig Selvey
    control valve.
  3. 4DoorMav74
    4DoorMav74 Youngin'
    Oceanside CA
    Thanx! i found one at Autokrafters for $260. Is that good for one? or really expensive?
  4. eddie1975
    eddie1975 Windsor Specialist
    Martinsburg, WV
    sold
    i bought the manuel one , so i can take the PS off, easy to install:thumbs2:
  5. don graham
    i just checked napa online and they have one for $199 and a $55.56 core charge. they also have a seal kit for $16.49. i'd bet that's all you need. but i've never played with one before.:)
  6. Craig Selvey
  7. 4DoorMav74
    4DoorMav74 Youngin'
    Oceanside CA
    ended up finding one at my local AutoZone for $144 after a $48 core charge so not so bad..
  8. don graham
    i'd a still tried the $16.44 seal kit from napa. :rolleyes:
  9. 4DoorMav74
    4DoorMav74 Youngin'
    Oceanside CA
    this has got to be the hardest part to get off in the world i have been trying for 2 hours now and am still stuck and taking the bar off from the top and pulling the whole thing out...
  10. 71gold
    the only way i have had any luck getting one to stop leaking...take it off and go to m/s (y)
    i spent over $200 on mine for leaking and then took it off..:cry:
    ...:cool: ...
  11. ratrodjake
    ratrodjake Member
    Tucson, AZ
    1974 Maverick 250 I6
    yeah same problem with my maverick....should i deal with trying to fix it... or convert to manual steering?
  12. 4DoorMav74
    4DoorMav74 Youngin'
    Oceanside CA
    well 3 hours later i still hadnt gotton it off and just had fluid all over... also cost me a good bit of money might be better to go to manual...
  13. Jamie Miles
    Go get your money back... take the old one off, remove power steering pump and lines. Drive. ;)
  14. ratrodjake
    ratrodjake Member
    Tucson, AZ
    so the steering box it has now is the same as a manual box?
  15. 71gold
    NO...better (y) turning is quicker from stop to stop...:bananaman
    ...:Handshake ...
