okay put up or shut up
Discussion in 'Drag Racing' started by Scootermagoo, Dec 23, 2006.
  1. Scootermagoo
    Scootermagoo Member
    Portland Oregon
    1973 Ford Maverick Grabber ginger & white factory 302 c-4 car LDO package
    http://www.badasscars.com/techtips.html#Reality (scroll down and find the red box for the power calculator)
    3400 lbs
    13.19 et
    104.5 mph
    calculated
    297.8hp at the rear wheels
    372hp at the flywheel
    approx
    edelbrock performer rpm package with the hydraulic cam they sell with a 750 holley is rated at 375 flywheel hp nice to see they are accurate on the advertised hp
    I have a 282s solid (similar specs as the hydraulic they sell) and a 600dp with a milled choke (650hp and spring awaits)
    whats your combo run
  2. Grabber71
    Grabber71 Milique Toast
    Vancouver Island, Canada
    '71 Grabber Maverick 351w
    Interesting link! heres how mine went:
    3200lbs
    12.27et
    112mph
    = 346hp at rear wheels
    433hp at flywheel.....according to this calculator
    Mine is a '69 351w, AFR 185 heads, 10:1 comp, Comp 274ex, preformer RPM intake, AED Holley 750dp and a set of bashed up Hooker 302headers
    I noticed that you car is rather heavy...have you weighed it or it is just a guess. I weighed mine a few years ago. With iron heads and steel rims(have alum now) and my tools in the trunk(tons of tools)..mine weighed in at 2985lbs(without me). I figure my weight numbers are high..but until I reweigh it I over estimate
  3. Scootermagoo
    Scootermagoo Member
    Portland Oregon
    first mines a 73 big front small rear bumper car it has a stereo with a 10 inch sub full exhaust steel wheels a 350-400lb driver the lightest pre stereo weight I have ever seen is 2940lbs so assuming 3000 lbs my 350-375 lbs and above dead weight I don't find 3400lbs unreasonable do you ? think the driver weight is high ask coop I'm 6ft5 and 350ish in fighting trim >;0
  4. T.L.
    T.L. Banned
    Southern Colorado
    '73 Maverick 2-door, V-8
    Personally, I think it's bogus....
  5. mavman
    mavman Member
    Arkansas
    Wish there was a dyno close by so I could check the figures I got on that site to actual figures. Mine runs 5.90s-6.00 1/8 at 115 (that's around a 9.60/140 1/4 mile). Site calc figured 723 HP. Sure sounds high. 2700 lbs (2520 w/o driver) weight figure.
  6. okibono
    okibono Member
    cali
    to the ground, or at the flywheel? That does sound a bit high for that weight.
  7. CornedBeef4.6L
    CornedBeef4.6L no longer here
    no longer here
    3100lbs
    12.65@108mph
    303@rwhp
    379hp@fly wheel
    306
    e303 cam Hyd Roller
    10.4 to comp ratio
    Roush 200 Iron Heads
    c4 3200 stall
    3.40 gears
    26 inch M/Tdrag radials
    625 Demon
    Best time at Thorn Hill Kentucky raceway.
    I added some ram air since but never got to test and motor is out for 331 stroker kit, rack and pinion install, and full resto. Who knows when I will be done.:huh:
  8. Scootermagoo
    Scootermagoo Member
    Portland Oregon
    physics is physics takes a certain amount of power to go from a dead stop to a speed at a distance it's not perfectly accurate but it's a close guess without actual numbers handy
    300rwhp is probably pretty close considering the package looser convertor and correct gearing and a harder leave with good tires might show 30-40hp more in the future maybe it wont we shall see
  9. M.A.V.
    M.A.V. Yep,my real initials.
    Macon,Georgia
    3,140 lbs
    12.20 et
    112.35 mph
    calculated
    344.7 rwhp
    430.9 fwhp
    :drive:
    308, Roller block
    X-303 cam
    Victor jr. heads/Sorpion roller rockers
    9.2 to 1 compression
    Offenhauser Tunnel ram with 2 Holley 450 mech. secondaries.
    Manual C-4 /3,800 converter
    9" with 4.11`s and a spool.
    26x8 M/T E.T. Drags.
    One thing I havent mentioned here yet is that on the following pass I was shifting at 6,500 for the first time...Car was feeling better than ever but I forgot to raise my rev limiter up from 6,600 were it has always been.
    At the top of 2nd gear it hit the limiter...I thought something had broken for a second and I lifted...THEN I realized what had happened :slap: and got back in to the throttle. That pass was a 12.22 @ 104.16 mph! I think it was about to run maybe a 12 flat. I couldn`t get back in line cause the staging lanes had closed.:(
    As soon as the track re-opens ...we will see.
  10. M.A.V.
    Macon,Georgia
    In my opinion that calculator may be reading a little on the high side...Just my opinion ;)
  11. eddie1975
    eddie1975 Windsor Specialist
    Martinsburg, WV
    sold
    yeah but gives you that warm fuzzy feeling :D
  12. T.L.
    T.L. Banned
    Southern Colorado
    I think it's low. For one thing, "25% drivetrain loss" is bogus, as pointed out by someone here in a previous thread. If a 250hp motor loses 62.5 horsepower at the rear wheels, why would a 500hp motor lose 125hp?! With that theory, the more powerful your engine is, the more it's gonna lose at the rear wheels. That's a bunch of crap.
    They even admit that [font=Arial, Helvetica, sans-serif]there are a lot of variables unaccounted for...[/font]
  13. Grabber71
    I agree with T.L. on this! of course I'm no expert of pretty much everything. As for comparison my car made 327hp & 333ft lbs torque at the wheels on the local Chassis Dyno a few months ago..so it may be a bit off on that end also(maybe, perhaps, possibly, plausable, not sure) But these number do sound better than what I have...
  14. stmanser
    Davenport, Iowa
    2800 pounds with me
    14.220
    96.96mph
    im at 195hp at wheels
    and 245 at engine
    sounds about right...
    get my heeads..cam.. gears and tires... and i am guessing i will be at about 300 hp..i hope
    my goal is 1 hp per cube...minimum
  15. tim keck
    sharps chapel,Tn
    Here's mine;
    3305 lbs
    12.41(w/150HP shot)
    109 mph
    337hp at wheels
    422hp at flywheel
    and....
    14.33(no bottle)
    95 mph
    221hp at wheels
    277hp at flywheel
    '88 standard bore roller 302
    stock shortblock save for B303 cam,ARP rod bolts/head studs,
    stock E7 heads
    Weiand 8011,holley 600
    hedman long tube headers
    2.25" dual w/Dynomax super turbo 2's
    '85 GT distributor,stock Duraspark box
    C4 w/3500 stall
    3.55's
    m&h g-60's
    NOS 150 shot(plate type system)
    '75 4dr...still got it,minus the driveline.But thats what it run back about '96 or so.
