old and new 302 balance question
Discussion in 'Technical' started by yerg, Oct 1, 2013.
  1. yerg
    yerg Member
    okolahoma
    Ok heres the question..we put a 95 mustang 302 engine in the maverick. It has the original flexplate to the 70 something tranny and the old balancer from the 70 302..I understand that there was a big difference in the weight balance between the two engines. So do I have to use the 95 flexplate and balancer or will it be ok because the flexplate and balancer match?
  2. Acornridgeman
    Wisconsin
    You will need the newer flexplate and harmonic balancer. They are matched to the internals of the engine.
  3. 71gold
    if the 95 had a 50 oz balancer you need that balancer and 50 oz flexplate.
  4. yerg
    yerg Member
    okolahoma
    Dang it..im thinking I should update the tranny to a newer c4..what do u recomend year wise or tranny wise? Will it hurt the engine to start it up and see if it runs? Also thinking about a hei distributor to clean up the engine bay..what do u recomend steel or chromemoly
  5. Krazy Comet
    You could get a pan fill C4 which use a 164 tooth flexplate but you still need a 50oz flexplate and front ballancer... If you transmission is a case fill you'll need a 50ox flexplate and that's aftermarke,t Ford never produced such a piece(I just bought one as I'm using a '92 5.0 engine in my Comet)...
    HEI yech, those things are uglier that the wiring that you can remove...
  6. 71gold
    ...:rofl2:...:sorry:
  7. Moneymaker 1
    Panama City Florida
