old cam, new lifters
Discussion in 'Technical' started by justin has a 74, Mar 18, 2010.
  1. justin has a 74
    kentucky
    Always Always Always get a new cam with new lifters but... i found a slightly bigger cam thats used with new lifters. i know the guy and he said there was no damage to the old lifters, they were just mixed up:rolleyes:
    yes or no and why;)
  2. maverick75
    If he did mix up the old lifters than that would be a reason why he has new lifters for them.
    used cam + used lifters no problem...
    used cam + used matched lifters is acceptable
    used cam + used mixed lifters is a problem.
  3. justin has a 74
    kentucky
    is that a yes, buy it
  4. bmcdaniel
    Yes, if you're talking about a flat tappet cam. Roller cams don't care. As the flat lifters slide and rotate on the cam lobes they, and the cam, develope a unique wear pattern. If you put a different lifter on a lobe than the one it was "matched" to, wear is accellerated. So if they get mixed, you're in trouble. If the new lifters haven't been broken in to the cam yet be sure to do that.
  5. mean_maverick
    justin, why not get everything u want for ur motor at once b4 u start installing anything??? this would save alot of time, aggervation and $$$ :huh:
  6. dkstuck
    dkstuck Member
    Latrobe Pa (Pgh)
    72 Maverick in drag
    Is your car running now?
  7. justin has a 74
    kentucky
    my car is running, this is a backup or possible money maker?
  8. rthomas771
    You dont wanna mix up rockers, fulcrums, pushrods, or lifters. Then need to be put back in the same location.
  9. baddad457
    How much does he want for it all ? That's the deciding question.
  10. baddad457
    And what do you call "slightly bigger"?
  11. justin has a 74
    kentucky
    its a magnum comp cam 480 lift 80 bucks but i was going to trade
  12. baddad457
    That's not "slightly bigger" That's slightly smaller.
  13. justin has a 74
    kentucky
    slightly bigger than mine lol
  14. baddad457
    No, it's slightly smaller than the 268H. It's a 260HR I'm sure, the lift is slightly more, but the duration is less. You'll may need custom pushrods to go with it too. I was thinkin it was a flat tappet cam, so $80 for the cam and lifters isn't a bad deal.
