older timing cover on newer block????
Discussion in 'Technical' started by Jap901, Apr 13, 2005.
  1. Jap901
    Jap901 Member
    Scotts Hill Tn
    71 mav 2 door
    Hello I have a 89 5.0 but my timing cover that don't have the spot for the oil dip stick or fuel pump, I know I can run a ele fuel pump but can i drill or tap a hole in the newer timing cover for the oil dip stick or will i have to get an old style cover and will it fit my 89 block?
    thanks for any input.
  2. Grabber5.0
    Grabber5.0 Gear-head wannabe
    Kansas City, MO
    71 Grabber
    You can do either one.
  3. maverick1970
    maverick1970 MCG State Rep
    Missouri
    I have seen timing covers that have the flat area cast into it just like the early covers except without the hole. I have also seen later timing covers without the flat area cast into them. If yours has it then you can drill the hole. Don't forget to plug the hole in the side of the block where the 5.0 dipstick was.
    Also keep in mind that the timing covers are different for standard and reverse rotation water pumps.
  4. Jap901
    Jap901 Member
    Scotts Hill Tn
    71 mav 2 door
    Hello thanks for the info but what do you mean by timing covers are different standard and reverse rotation water pumps?
    you got me on this one :huh:
  5. maverick1970
    Missouri
  6. Jap901
    Jap901 Member
    Scotts Hill Tn
    71 mav 2 door
    Thanks Maverick1970 for the info (y) I can say I learned something today:clap:
    thanks again
