open differential vs limited slip
Discussion in 'Technical' started by bdf, Nov 16, 2009.
  1. bdf
    bdf Member
    Northern Michigan
    77 Mav customized to look like a 72 Grabber
    For regular street driving, is it worthwhile to go to a limited slip differential? I'm trying to decide if it's worth the upgrade. I'm currently driving a 302 with a 3.55 rear gear. Any thoughts?
  2. 71gold
    not if you don't have a...tire spin...problem...(y)
  3. 302-72-mav
    302-72-mav Member
    sactown CA
    posi is the way to go
    but you will save $ when it come's to buying tires
  4. PaulS
    If you are driving it on the street there is no advantage to a limited slip.
    What you might gain in traction on dry roads you lose in wet or snow.
    Since where I live it is wet more often than dry it actually is worse driving with a limited slip rear than with the open rear gears. I have tried it both ways and I find it safer to use the open differential.
  5. rthomas771
    What PaulS said :yup:
  6. darren
    Agreed. Limited slip will put you sideways in the snow real fast. My Jeep has trac loc in the rear and its a nightmare in 2wd in snow but when you couple it with 4wd it works great.
  7. RMiller
    RMiller My name is Rick
    Kennewick, WA
    1971 Maverick Grabber
    Mine's getting a limited slip for sure. I don't want it for additional traction so much as I want it so I can get sideways!!!!!:chirp::thumbs2:
  8. PaulS
    If you run the limited slip on the road you are going to have to get used to being real conservative or you will be "sideways" at the wrong time too often.
  9. Lee Richart
    Lee Richart Member
    Redford, MI
    1973 Maverick LDO 421W
    If you live in Northern Michigan, you shouldn't need to ask that question. You will want it even more if you upgrade that 302. I say go for it.
    Lee "THE MAV" Richart
  10. RMiller
    Kennewick, WA
    It's all in knowing your car and how much right foot you can give it. My GTO would spin at the drop of the hat and I did just fine with it.
  11. PaulS
    I have had both types in my cars and it seems the less power they had the harder they were to control. The biggest problem was driving down the road and have the conditions change before i could adjust..... Not a pretty site. I have never had a "problem" with the open differentials other than blowing two of the 7.5" ones out in my 200" powered falcon with one of my transmissions in it.
  12. baddad457
    :thumbs2: I agree totally. As for "getting sideways" that's something you learn to avoid when the situation arises. It's called "experience". ;) Limited slip will get you out of the snow faster than an open diff. Especially if and when you put the tire chains on. ;)
  13. bmcdaniel
    bmcdaniel Senile Member
    3.50:1, or there about, are the stiffest gears I would run"1-legged".
  14. shanelindley
    shanelindley Member
    paris tn
    1974 comet gt
    just put a mini spool in mine with a set of 4.11 gears. i could not do the one wheel peel any longer
  15. PaulS
    Snow is pretty easy to deal with when running a spool or posi rear end. The one that throws you is when you are driving and run into a tiny bit of water on the road after a long dry spell or when you run into a patch of black ice. Those are the kind of things that always surprised me.
    It is much easier to control a one wheel wonder in those conditions than it is with a locked rear end. If one wheel spins the other can still track but with both spinning.... well you get the idea.
